syncronize local command always deletes remote files.
abbotn
The remote files are always deleted with the synchronize command.
I need the remote files to stay put.
Here is a sample of the command I'm using, sans the sensitive information.
C:\>"C:\Program Files\WinSCP\WinSCP.com" /command "open *@*.com" "synchronize local ""c:\Space test""" "Exit"
Please help, thanks.
Re: syncronize local command always deletes remote files.
The only explanation is that you have set files to be deleted in GUI.
Consider isolating the script run from GUI configuration:
https://winscp.net/eng/docs/scripting#configuration
If that does not help, please attach a full log file showing the problem (using the latest version of WinSCP).
