Moving local to remote & copying remote to local automatically & Excluding subdirectories
scargo
Aloha,
I am unable to automatically look for new files with a specific file extension on the local windows directory and move them (not copy) to a specific remote UNIX directory.
I also want to copy files (not move them) with specific extensions automatically from the remote UXIX machine directory, excluding all subdirectories, to the local windows directory. I'll let UNIX take care of cleaning up old files.
In other words, I want to move in one direction and copy in the other direction automatically in the background. I'd like to try running the program as a service, using the program called "AtYourService"
I also want to exclude subdirectories from synchronization, but the program seems to include all subdirectories when doing so.
I noticed that there is a command line "Upload" but not a "Download"
Can any of these commands be run from the windows task scheduler?
Scargo
Re: Moving local to remote & copying remote to local automatically & Excluding subdirectories
Next version of WinSCP will support scripting to allow automation. But it won't allow transfer by extension yet.
You may partially succeed using synchronize command and its "exclude by mask" feature. Maybe you will be able to include only the files you want by excluding all other.
barbudo wrote:
I'm impatiently waiting for the new version with scripting. Any idea when it's coming out?
Most probably this wednesday.
barbudo
Thanks for the new version. My goal is to automate backups from the Linux server to a local usb drive. So I created a simple script file containing:
synchronize local e:\backup\home /home
synchronize local e:\backup\var-mail /var/spool/mail
Then I execute:
winscp3.com user@192.168.xx.xx /script=backup.script
It all seems to work fine but when I run this again I noticed that ALL files are copied including those that I know were not modified. In other words synchronize behaves like get recopying large amount of data unnecessarily. Could it be because of file system differences? My local box is winxp-sp2 (ntfs). Is there a way around this? Am I doing something wrong?
Compare file in local and remote directories and check for timestamp. They will probably differ. There are several posts in the forum about the problem already.
I'm lost with the option ins remote update vs. sync. I don't think the english translation is very good, could someone explain how these procedures work and differ?
Yes, I want a local directory with updated content to check the remote directory and update any NEWER files, but I can't determine which method is needed and which method will FUBAR the whole thing.
thanks.
If all files are uploaded every time, it is probably because there is some problem with timestamps.
Login with WinSCP and check the timestamps in panels. There will probably be some difference. Let me know what difference. Also let me know what protocol do you use, SCP or SFTP?
