explorer view: download to wrong directory
smitty123
Canada
hey there, reporting 2 bugs in winscp 5.7.4
i just noticed this bug in explorer interface: when right-click on a file or folder => Download...
(1) it downloaded to "my documents" and (2) without asking where i want it saved.
i was logued in with a login profile/session with set Local and remote directories in Session settings => Environment -> Directories
In explorer mode, it started fine in remote dir but not local dir. (this may be why. please to check if "local dir" variable is properly init. with user settings)
In commander mode, it started properly in remote/local dirs.
Re: explorer view: download to wrong directory
You must have disabled confirmation of Transferring of files at:
https://winscp.net/eng/docs/ui_pref_environment
There's no local panel in Explorer interface.
smitty123
Canada
my point was that it shouldn't transfer to my documents, it should show a popup with the computer's folders for the user to choose from, that's what the "..." are for.
cheers
True. WinSCP does (by default) show the popup.
You must have disabled it.
smitty123
Canada
you're right :) for some reason it was unchecked in view=>prefs=> env =>confirmations =>transfers
what's confusing is that, that popup does not show when it is unchecked but the ellipsis symbol in the context menu "..." tells the user to expect a prompt.
maybe it shouln't be disabled but instead add another context menu entry to download to [whateverlastfolder]?
that could be usefull and not break the windows standards.
