which ports are using to connect
Jimmy
Hi :D ,
Which port are unsing by WinSCP, because i've a viruswall with proxy and a firewall
between my computer and my web - server
Re: which ports are using to connect
The one that you specify on "Session" tab of login dialog. This is usually default port of SSH: 22.
Jimmy wrote:
Is only this port used ?
Yes.
Isnt so that the client is using a low port when authentication occurd and then use a port above 1023.
If so how can i change winscp to use UsePrivilegedPort = no 8)
