Little problem with timestamps
eXemonY
It must be an stupid question, but i can't figure it out by myself..
Well the problem I'm having is, my client saves files with the timestamp DD/MM/YYYY HH:MM:SS and my server does it as DD/MM/YYYY HH:MM I would like to know how i can mask the timestamps of my client while synchronizing it.
Hope you can understand it, not native though.
Thank you in advance.
eXemonY
First of all, thanks for your answer.
Well, my computer is the 'client' and I save the files in DD/MM/YYYY HH:MM:SS, now I encounter the problem while I try to synchronize my files with my NAS that saves the modification date as: DD/MM/YYYY HH:MM, so, when I compare them it always says I have a newer one as it has seconds.
I cannot connect my NAS through SFTP only FTP, so I cannot use the 'synchronize timestamps' option.
Thanks again, hope you could help me ;)
If the FTP server reports times with minute-precision only, WinSCP recognizes that, and considers minutes only, when comparing files.
eXemonY
Thank you, hope it helps. In that case I synchronized 5 files, all starting as: 'Jesus-MINHO_***' and all of them were already uploaded. Thank you ;)
  • log.log (49.94 KB, Private file)
