Script to get only yesterday folder
Mahdi Bashiri
Hi
I need script to get only yesterday folder exactly, so i use get -filemask="*>=1D" but this command get all folder before today, please let me know how can i use this command to get only yesterday folder, also how can i use that on batch script file.
Regards,
Mahdi
Re: Script to get only yesterday folder
The above command will download all files created in the last 24-hours. It has no effect on directories. So it will recreate the complete remote directory structure locally, while most of the folders should be empty.
Is there a way to identify the yesterdays folder? By a name?
You may also be able to use a technique described here:
https://winscp.net/eng/docs/script_download_most_recent_file
Mahdi Bashiri
Script to get yesterday folder only
Yes, The folder name has date pattern like yyyy-mm-dd, but the date pattern is in persian (Iranian) Date, for example 1394-05-03 that equals to 2015-07-24. also the folder name created by program itself on outside ftp server and we can not any access to change this pattern.
