Winscp script not connecting but session fine via GUI
dogwhiskers
There is a session created using ftps to connect to a 3rd party. The connection is fine when using the GUI although sometimes it can take over 10 seconds or it can fail but then a reconnect makes the connection connect fine.
Whn calling hte same session via a batch script it more than often fails to connect.
I have tried increasing the timeout on the session from 15 to 45 seconds however the connection still fails in the batch script. When I try the GUI the connection works usually 1st time.
Is there a switch that can be used to help the connection reconnect if it initially fails when run in batch mode? Log below
batch continue
reconnecttime 120
confirm off
Connecting to xxx.xx.xxx.xxx:990 ...
TLS connection established. Waiting for welcome message...
Connection failed.
Using TLSv1, cipher TLSv1/SSLv3: AES128-SHA, 2048 bit RSA
Disconnected from server
Connection failed.
confirm off
No session.
Re: Winscp script not connecting but session fine via GUI
Please attach a full log file on Debug 2 log level showing the problem (using the latest version of WinSCP).
kbh
Winscp script not connecting but session fine via GUI.
I am having the same problem as described above.
When using script never connects. When using GUI never connects the first time but connects on reconnect attempts.
Also below is the batch file content
cd C:\Program Files (x86)\WinSCP
winscp.com /command ^
"option batch on" ^
"option confirm off" ^
"open ftp://xxxxx:xxxxxx@<IP>/XXX/ -implicit -certificate=""xx:xx:xx"" -passive "
"cd /FISA" ^
"lcd c:\projects\XXXX_Files" ^
"put -delete xxxx.txt.pgp" ^
"exit"
  • FTP.log (15.21 KB, Private file)
Description: WINSCP Log file
kbh
Added log file with debug 2 level messages
  • FTP.log (12.84 KB, Private file)
Description: WinSCP log with debug 2 messages
kbh
Re: Winscp script not connecting but session fine via GUI.
Did you try setting a longer timeout?
Martin,
Appreciate your response.
Yes, tried with 600 seconds timeout value, still get same error.
Using TLSv1.2, cipher TLSv1/SSLv3: AES128-SHA256, 2048 bit RSA
Connection failed.
Below is the new batch file. Also this problem is only with latest version (5.7.7), works well with version 5.5.1
cd C:\WinSCP577
"option batch" ^
"open ftps://xxx:xxxx@xx.xxx.xxx.xx:990 -implicit -certificate=""xx:xx:xx...."" -timeout=""600""" ^
"cd /XXXX" ^
"put -delete xxxxx.txt.pgp" ^
"exit"
