WinSCP failure when uploading - pscp works
Jens
I'm getting a "General failure" when uploading to my home
dir on a particular server.
putty's pscp works fine, though.
I had the problem first with 3.6.1, upgraded to 3.6.8 and it's
still the same.. downloading and directory listing works fine,
but I cannot upload into any directory. (tried sftp and scp methods,
no luck)
here are the relevant parts of the log:
. Connecting to XXXXXXXX port 22
. Server version: SSH-1.99-OpenSSH_3.6.1p2
. We claim version: SSH-2.0-WinSCP-release-3.6.8
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 63, Number: 528
. Real path is '/linux/home/linux/jaw'
. Listing directory "/linux/home/linux/jaw".
> Type: SSH_FXP_OPENDIR, Size: 30, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 4723, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
< Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< Status/error code: 0
. Startup conversation with host finished.
. Copying 1 files/directories to remote directory "/linux/home/linux/jaw/"
. PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: Yes; Mask: *.*
. TM: M; ExclM:
. AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. File: "C:\foo.txt"
. Copying "C:\foo.txt" to remote directory started.
. Ascii transfer mode selected.
. Opening remote file.
> Type: SSH_FXP_OPEN, Size: 54, Number: 1795
< Type: SSH_FXP_STATUS, Size: 24, Number: 1795
< Status/error code: 4, Message: 1795, Server: Failure, Language:
> Type: SSH_FXP_LSTAT, Size: 38, Number: 2055
< Type: SSH_FXP_STATUS, Size: 29, Number: 2055
< Status/error code: 2, Message: 2055, Server: No such file, Language:
* (ETerminal) General failure (server should provide error description).
* Error code: 4
* Error message from server: Failure
* Request code: 3
. Asking user:
I saw similar problems searching this forum, but no solution so far.
if this is a problem with the server not conforming to the protocol,
why does uploading work fine with pscp ?
regards,
Jens
Re: WinSCP failure when uploading - pscp works
Please answer me following questions:
- Had some older version of WinSCP worked? (before 3.6.1???)
- Does the file being uploaded already exists? If it does, are you able to upload file that does not exists? And vice versa.
- Can you try to upload file using PSFTP tool
Also please enable SFTP protocol logging by importing following registry settings:
REGEDIT4
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Logging]
"LogProtocol"=dword:00000001
Then generate the same log as you have done in your post. It should include SFTP packet dumps.
Thanks.
Jens
I've tried with 3.6.1 for the first time, but went now and tried 3.5.6 and 2.3.0:
2.3.0: I can't even get a directory listing:
Unexpected directory listing line "insgesamt 1248".
Invalid rights description "nsgesamt "
the same happens if I try later versions with SCP protocol only, so I guess
this server only wants SFTP (which 2.3.0 doesn't seem to have yet)
3.5.6: exact same behaviour as later versions, listing, downloading works,
upload gives the general failure.
And here is testing with SFTP protocol logging enabled on 3.6.8 -
my comments are prepended with "-->":
> 01,00,00,00,05,
< 02,00,00,00,03,
> C8,00,00,00,C8,00,00,00,1D,77,69,6E,73,63,70,40,77,69,6E,73,63,70,2E,73,6F,
> 75,72,63,65,66,6F,72,67,65,2E,6E,65,74,
< 65,00,00,00,C8,00,00,00,08,00,00,00,15,4F,70,65,72,61,74,69,6F,6E,20,75,6E,
< 73,75,70,70,6F,72,74,65,64,00,00,00,00,
> 10,00,00,02,10,00,00,00,01,2E,
< 68,00,00,02,10,00,00,00,01,00,00,00,15,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,
< 6C,69,6E,75,78,2F,6A,61,77,00,00,00,15,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,
< 6C,69,6E,75,78,2F,6A,61,77,00,00,00,00,
> 0B,00,00,03,0B,00,00,00,15,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,
< 66,00,00,03,0B,00,00,00,04,00,00,00,00,
> 0C,00,00,04,0C,00,00,00,04,00,00,00,00,
< 68,00,00,04,0C,00,00,00,2A,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 72,2D,78,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,
< 20,20,20,20,20,20,34,30,39,36,20,53,65,70,20,32,39,20,31,34,3A,33,34,20,2E,
< 00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,41,ED,41,
< 2B,60,2E,41,5A,AB,BF,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,62,69,6E,20,20,20,20,20,
< 20,20,20,20,20,34,30,39,36,20,53,65,70,20,32,33,20,31,32,3A,33,31,20,2E,2E,
< 00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,01,00,00,41,ED,41,
< 2A,F3,6A,41,52,A6,0F,00,00,00,0A,23,2E,70,72,6F,66,69,6C,65,23,00,00,00,42,
< 2D,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,
< 6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,20,39,37,20,53,65,70,20,33,30,20,
< 20,31,39,39,37,20,23,2E,70,72,6F,66,69,6C,65,23,00,00,00,0F,00,00,00,00,00,
< 00,00,61,00,00,0E,27,00,00,00,C9,00,00,81,C0,41,2B,60,A5,34,30,31,A7,00,00,
< 00,0E,2E,61,73,57,65,64,69,74,2D,70,72,65,66,73,00,00,00,46,2D,72,77,2D,2D,
< 2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,
< 20,20,20,20,20,20,20,20,20,20,33,31,20,4A,61,6E,20,32,32,20,20,31,39,39,37,
< 20,2E,61,73,57,65,64,69,74,2D,70,72,65,66,73,00,00,00,0F,00,00,00,00,00,00,
< 00,1F,00,00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,A5,32,E5,79,A9,00,00,00,
< 0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,45,2D,72,77,2D,2D,2D,2D,
< 2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,
< 20,20,20,20,20,20,20,32,34,36,20,41,75,67,20,32,34,20,20,32,30,30,31,20,2E,
< 62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,00,00,00,00,F6,00,
< 00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,A5,3B,86,49,D3,00,00,00,08,2E,65,
< 62,74,70,72,69,76,00,00,00,40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,31,
< 20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,
< 39,36,20,41,75,67,20,32,34,20,31,37,3A,33,35,20,2E,65,62,74,70,72,69,76,00,
< 00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,41,ED,41,2B,
< 60,2F,41,2B,60,2F,00,00,00,04,2E,65,6C,6D,00,00,00,3C,64,72,77,78,2D,2D,2D,
< 20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,31,37,3A,33,35,20,2E,
< 65,6C,6D,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,
< 41,C0,41,2B,60,2F,41,2B,60,2F,00,00,00,06,2E,65,6D,61,63,73,00,00,00,3E,2D,
< 72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,
< 69,6E,75,78,20,20,20,20,20,20,20,20,36,38,30,30,20,4E,6F,76,20,20,37,20,20,
< 31,39,39,36,20,2E,65,6D,61,63,73,00,00,00,0F,00,00,00,00,00,00,1A,90,00,00,
< 0E,27,00,00,00,C9,00,00,81,80,41,2B,60,A5,32,81,67,B4,00,00,00,07,2E,66,76,
< 77,6D,72,63,00,00,00,3F,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,
< 61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,31,38,32,35,39,
< 20,4E,6F,76,20,32,32,20,20,31,39,39,37,20,2E,66,76,77,6D,72,63,00,00,00,0F,
< 00,00,00,00,00,00,47,53,00,00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,A5,34,
< 76,45,5A,00,00,00,08,2E,68,69,73,74,6F,72,79,00,00,00,40,2D,72,77,2D,2D,2D,
< 2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,
< 20,20,20,20,20,20,20,31,30,36,37,20,4D,61,72,20,31,35,20,20,32,30,30,30,20,
< 2E,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,00,00,00,04,2B,00,00,0E,27,00,
< 00,00,C9,00,00,81,80,41,2B,60,A6,38,CF,B5,7D,00,00,00,07,2E,68,79,70,65,72,
< 62,00,00,00,3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,
< 20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,
< 67,20,32,34,20,31,37,3A,33,35,20,2E,68,79,70,65,72,62,00,00,00,0F,00,00,00,
< 00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,41,C0,41,2B,60,2F,41,2B,60,2F,
< 00,00,00,06,2E,6C,6F,67,69,6E,00,00,00,3E,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,
< 20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,
< 20,20,20,34,39,34,20,4F,63,74,20,20,38,20,20,31,39,39,37,20,2E,6C,6F,67,69,
< 6E,00,00,00,0F,00,00,00,00,00,00,01,EE,00,00,0E,27,00,00,00,C9,00,00,81,80,
< 41,2B,60,A6,34,3B,8E,B0,00,00,00,0D,2E,6C,79,6E,78,5F,63,6F,6F,6B,69,65,73,
< 00,00,00,45,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,
< 20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,20,36,37,20,4A,75,6C,
< 20,20,33,20,20,32,30,30,32,20,2E,6C,79,6E,78,5F,63,6F,6F,6B,69,65,73,00,00,
< 00,0F,00,00,00,00,00,00,00,43,00,00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,
< A6,3D,23,6C,AC,00,00,00,0C,2E,6D,61,69,6C,62,6F,78,6C,69,73,74,00,00,00,44,
< 2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,
< 72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,20,4A,75,6E,20,31,30,20,
< 20,31,39,39,39,20,2E,6D,61,69,6C,62,6F,78,6C,69,73,74,00,00,00,0F,00,00,00,
< 00,00,00,00,00,00,00,0E,27,00,00,00,00,00,00,81,A4,41,2B,60,A6,37,5F,4D,B9,
< 00,00,00,09,2E,6E,65,74,73,63,61,70,65,00,00,00,41,64,72,77,78,72,2D,78,72,
< 2D,78,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,
< 20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,31,37,3A,33,35,20,2E,6E,
< 65,74,73,63,61,70,65,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,00,
< 00,C9,00,00,41,ED,41,2B,60,2F,41,2B,60,30,00,00,00,07,2E,6E,65,77,73,72,63,
< 00,00,00,3F,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,
< 20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,34,38,20,46,65,62,
< 20,20,31,20,20,31,39,39,37,20,2E,6E,65,77,73,72,63,00,00,00,0F,00,00,00,00,
< 00,00,0F,D0,00,00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,A7,32,F2,AE,F2,00,
< 00,00,06,2E,6E,6F,74,65,73,00,00,00,3E,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,
< 20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,
< 20,20,32,32,39,20,46,65,62,20,20,34,20,20,31,39,39,37,20,2E,6E,6F,74,65,73,
< 00,00,00,0F,00,00,00,00,00,00,00,E5,00,00,0E,27,00,00,00,C9,00,00,81,80,41,
< 2B,60,A7,32,F6,71,48,00,00,00,08,2E,70,72,6F,66,69,6C,65,00,00,00,40,2D,72,
< 77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,
< 6E,75,78,20,20,20,20,20,20,20,20,20,20,39,39,20,41,70,72,20,20,33,20,20,31,
< 39,39,37,20,2E,70,72,6F,66,69,6C,65,00,00,00,0F,00,00,00,00,00,00,00,63,00,
< 00,0E,27,00,00,00,C9,00,00,81,C0,41,2B,60,A7,33,44,04,2A,00,00,00,0A,2E,73,
< 67,69,68,65,6C,70,72,63,00,00,00,42,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,
< 20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,
< 20,20,33,30,20,4F,63,74,20,32,33,20,20,31,39,39,37,20,2E,73,67,69,68,65,6C,
< 70,72,63,00,00,00,0F,00,00,00,00,00,00,00,1E,00,00,0E,27,00,00,00,C9,00,00,
< 81,80,41,2B,60,A7,34,4E,79,97,00,00,00,04,2E,73,73,68,00,00,00,3C,64,72,77,
< 78,72,2D,78,72,2D,78,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,
< 75,78,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,31,37,3A,
< 33,35,20,2E,73,73,68,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,00,
< 00,C9,00,00,41,ED,41,2B,60,30,41,2B,60,30,00,00,00,0B,2E,58,61,75,74,68,6F,
< 72,69,74,79,00,00,00,43,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,
< 61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,34,39,34,
< 20,4F,63,74,20,31,36,20,20,32,30,30,33,20,2E,58,61,75,74,68,6F,72,69,74,79,
< 00,00,00,0F,00,00,00,00,00,00,01,EE,00,00,0E,27,00,00,00,C9,00,00,81,80,41,
< 2B,60,A5,3F,8E,7D,D2,00,00,00,08,2E,78,69,6E,69,74,72,63,00,00,00,40,2D,72,
< 6E,75,78,20,20,20,20,20,20,20,20,20,37,32,39,20,4F,63,74,20,31,30,20,20,31,
< 39,39,37,20,2E,78,69,6E,69,74,72,63,00,00,00,0F,00,00,00,00,00,00,02,D9,00,
< 00,0E,27,00,00,00,C9,00,00,81,C0,41,2B,60,A7,34,3D,73,45,00,00,00,05,31,2E,
< 7A,69,70,00,00,00,3D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,
< 77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,33,33,30,37,36,20,
< 4A,75,6E,20,32,35,20,20,32,30,30,33,20,31,2E,7A,69,70,00,00,00,0F,00,00,00,
< 00,00,00,81,34,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A7,3E,F9,96,01,
< 00,00,00,0D,61,64,64,72,65,73,73,65,73,2E,74,78,74,00,00,00,45,2D,72,77,2D,
< 72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,
< 78,20,20,20,20,20,20,20,20,20,31,35,37,20,4F,63,74,20,31,34,20,20,31,39,39,
< 39,20,61,64,64,72,65,73,73,65,73,2E,74,78,74,00,00,00,0F,00,00,00,00,00,00,
< 00,9D,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A8,38,05,E0,C8,00,00,00,
< 05,64,75,6D,6D,79,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,31,
< 39,36,20,41,75,67,20,32,34,20,31,37,3A,33,35,20,64,75,6D,6D,79,00,00,00,0F,
< 00,00,00,00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,41,ED,41,2B,60,31,41,
< 2B,60,31,00,00,00,08,64,75,6D,70,73,74,65,72,00,00,00,40,64,72,77,78,2D,2D,
< 20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,31,37,3A,33,35,20,
< 64,75,6D,70,73,74,65,72,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,27,00,
< 00,00,C9,00,00,41,C0,41,2B,60,31,41,2B,60,32,00,00,00,0C,65,6E,76,70,6C,61,
< 6E,65,2E,6A,70,67,00,00,00,44,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,31,32,30,
< 32,39,20,4D,61,79,20,32,36,20,20,32,30,30,33,20,65,6E,76,70,6C,61,6E,65,2E,
< 6A,70,67,00,00,00,0F,00,00,00,00,00,00,2E,FD,00,00,0E,27,00,00,00,C9,00,00,
< 81,A4,41,2B,60,A8,3E,D1,D6,E6,00,00,00,07,66,6F,6F,2E,63,70,70,00,00,00,3F,
< 6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,36,39,20,53,65,70,20,32,39,20,
< 31,34,3A,33,34,20,66,6F,6F,2E,63,70,70,00,00,00,0F,00,00,00,00,00,00,0F,E5,
< 00,00,0E,27,00,00,00,C9,00,00,81,A4,41,5A,AB,BF,41,5A,AB,C1,00,00,00,0A,69,
< 6E,64,65,78,2E,68,74,6D,6C,00,00,00,42,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 20,33,37,35,34,20,4A,75,6C,20,33,30,20,20,31,39,39,39,20,69,6E,64,65,78,2E,
< 68,74,6D,6C,00,00,00,0F,00,00,00,00,00,00,0E,AA,00,00,0E,27,00,00,00,C9,00,
< 00,81,A4,41,2B,60,A8,37,A0,F3,12,00,00,00,09,6A,61,76,61,2E,68,74,6D,6C,00,
< 00,00,41,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,
< 20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,32,31,39,31,20,4A,75,6C,20,
< 33,30,20,20,31,39,39,39,20,6A,61,76,61,2E,68,74,6D,6C,00,00,00,0F,00,00,00,
< 00,00,00,08,8F,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A8,37,A0,F3,13,
< 00,00,00,07,6A,61,77,2E,64,61,74,00,00,00,3F,2D,72,77,2D,2D,2D,2D,2D,2D,2D,
< 20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,
< 20,20,20,20,20,20,32,20,46,65,62,20,32,36,20,20,31,39,39,37,20,6A,61,77,2E,
< 64,61,74,00,00,00,0F,00,00,00,00,00,00,00,02,00,00,0E,27,00,00,00,C9,00,00,
< 81,80,41,2B,60,A8,33,13,74,11,00,00,00,09,6B,75,65,6E,64,2E,7A,69,70,00,00,
< 00,41,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,
< 20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,35,37,37,35,20,4A,75,6E,20,33,
< 30,20,20,32,30,30,33,20,6B,75,65,6E,64,2E,7A,69,70,00,00,00,0F,00,00,00,00,
< 00,00,16,8F,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A8,3F,00,04,93,00,
< 00,00,09,6C,64,65,6D,6F,2E,7A,69,70,00,00,00,41,2D,72,77,2D,72,2D,2D,72,2D,
< 2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,
< 20,20,20,33,34,31,33,34,20,41,75,67,20,20,34,20,20,31,39,39,39,20,6C,64,65,
< 6D,6F,2E,7A,69,70,00,00,00,0F,00,00,00,00,00,00,85,56,00,00,0E,27,00,00,00,
< C9,00,00,81,A4,41,2B,60,A8,37,A8,6D,24,00,00,00,04,4D,61,69,6C,00,00,00,3C,
< 64,72,77,78,72,77,78,72,77,74,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,
< 6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,
< 31,37,3A,33,35,20,4D,61,69,6C,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,0E,
< 27,00,00,00,C9,00,00,43,FF,41,2B,60,31,41,2B,60,31,00,00,00,06,6E,73,6D,61,
< 69,6C,00,00,00,3E,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,
< 20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,34,30,39,36,20,41,
< 75,67,20,32,34,20,31,37,3A,33,35,20,6E,73,6D,61,69,6C,00,00,00,0F,00,00,00,
< 00,00,00,10,00,00,00,0E,27,00,00,00,C9,00,00,41,C0,41,2B,60,32,41,2B,60,32,
< 00,00,00,09,6E,75,72,62,73,2E,7A,69,70,00,00,00,41,2D,72,77,2D,72,2D,2D,72,
< 2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,
< 20,20,20,20,20,38,38,36,30,20,4A,75,6E,20,32,33,20,20,32,30,30,33,20,6E,75,
< 72,62,73,2E,7A,69,70,00,00,00,0F,00,00,00,00,00,00,22,9C,00,00,0E,27,00,00,
< 00,C9,00,00,81,A4,41,2B,60,A9,3E,F7,10,93,00,00,00,11,70,32,39,37,2D,6D,69,
< 63,68,61,6C,69,6B,2E,70,64,66,00,00,00,49,2D,72,77,2D,72,2D,2D,72,2D,2D,20,
< 34,37,38,32,30,33,20,4A,75,6E,20,31,30,20,20,32,30,30,33,20,70,32,39,37,2D,
< 6D,69,63,68,61,6C,69,6B,2E,70,64,66,00,00,00,0F,00,00,00,00,00,07,4B,FB,00,
< 00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A9,3E,E5,A9,64,00,00,00,07,70,69,
< 64,2E,62,6E,63,00,00,00,3F,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,20,20,
< 35,20,53,65,70,20,32,34,20,20,31,39,39,39,20,70,69,64,2E,62,6E,63,00,00,00,
< 0F,00,00,00,00,00,00,00,05,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,A9,
< 37,EB,BF,E4,00,00,00,0B,70,75,62,6C,69,63,5F,68,74,6D,6C,00,00,00,43,64,72,
< 77,78,72,2D,78,72,2D,78,20,20,20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,
< 6E,75,78,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,34,20,31,37,
< 3A,33,36,20,70,75,62,6C,69,63,5F,68,74,6D,6C,00,00,00,0F,00,00,00,00,00,00,
< 10,00,00,00,0E,27,00,00,00,C9,00,00,41,ED,41,2B,60,33,41,2B,60,62,00,00,00,
< 01,71,00,00,00,39,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6A,61,77,
< 20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,31,34,37,38,20,4F,
< 63,74,20,32,35,20,20,31,39,39,39,20,71,00,00,00,0F,00,00,00,00,00,00,05,C6,
< 00,00,0E,27,00,00,00,C9,00,00,81,80,41,2B,60,D8,38,14,7B,9F,00,00,00,0A,73,
< 6B,65,74,63,68,2E,7A,69,70,00,00,00,42,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 20,20,31,20,6A,61,77,20,20,20,20,20,20,6C,69,6E,75,78,20,20,20,20,20,20,35,
< 38,30,30,34,30,20,4D,61,79,20,31,36,20,20,32,30,30,33,20,73,6B,65,74,63,68,
< 2E,7A,69,70,00,00,00,0F,00,00,00,00,00,08,D9,C8,00,00,0E,27,00,00,00,C9,00,
< 00,81,A4,41,2B,60,D9,3E,C4,D1,FC,00,00,00,08,75,72,6C,73,2E,74,78,74,00,00,
< 00,40,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6A,61,77,20,20,20,20,
< 20,20,6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,32,30,38,20,4A,75,6E,20,31,
< 30,20,20,32,30,30,33,20,75,72,6C,73,2E,74,78,74,00,00,00,0F,00,00,00,00,00,
< 00,00,D0,00,00,0E,27,00,00,00,C9,00,00,81,A4,41,2B,60,D9,3E,E5,CB,28,
> 0C,00,00,05,0C,00,00,00,04,00,00,00,00,
< 65,00,00,05,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 00,00,00,
> 04,00,00,06,04,00,00,00,04,00,00,00,00,
< 65,00,00,06,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
---> no problems so far. now uploading "foo.cpp" (which already exists on the server!)
. TM: M; ExclM:
. File: "C:\foo.cpp"
. Copying "C:\foo.cpp" to remote directory started.
> 03,00,00,07,03,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,2F,66,6F,6F,2E,63,70,70,00,00,00,3A,00,00,00,01,00,00,00,00,
> 00,00,00,09,
< 65,00,00,07,03,00,00,00,04,00,00,00,07,46,61,69,6C,75,72,65,00,00,00,00,
> 07,00,00,08,07,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
< Type: SSH_FXP_ATTRS, Size: 37, Number: 2055
< 69,00,00,08,07,00,00,00,0F,00,00,00,00,00,00,0F,E5,00,00,0E,27,00,00,00,C9,
< 00,00,81,A4,41,5A,AB,BF,41,5A,AB,C1,
. Asking user:
. Remote file 'foo.cpp' already exists. Overwrite?
---> yep.
. New: 9 bytes, 30.09.2004 12:20:30
. Existing: 4069 bytes, 29.09.2004 14:34:09 ()
> Type: SSH_FXP_OPEN, Size: 54, Number: 2307
> 03,00,00,09,03,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,2F,66,6F,6F,2E,63,70,70,00,00,00,1A,00,00,00,01,00,00,00,00,
> 00,00,00,09,
< Type: SSH_FXP_HANDLE, Size: 13, Number: 2307
< 66,00,00,09,03,00,00,00,04,00,00,00,00,
> Type: SSH_FXP_WRITE, Size: 34, Number: 2566
> 06,00,00,0A,06,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,09,
> 64,73,66,6B,6A,68,73,6B,6A,
< Type: SSH_FXP_STATUS, Size: 24, Number: 2566
< 65,00,00,0A,06,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
> Type: SSH_FXP_CLOSE, Size: 13, Number: 2820
> 04,00,00,0B,04,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_STATUS, Size: 24, Number: 2820
< 65,00,00,0B,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
> Type: SSH_FXP_SETSTAT, Size: 50, Number: 3081
> 09,00,00,0C,09,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,2F,66,6F,6F,2E,63,70,70,00,00,00,08,41,5B,DE,00,41,5B,DD,EE,
< Type: SSH_FXP_STATUS, Size: 24, Number: 3081
< 65,00,00,0C,09,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
> Type: SSH_FXP_OPENDIR, Size: 30, Number: 3339
> 0B,00,00,0D,0B,00,00,00,15,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,
< Type: SSH_FXP_HANDLE, Size: 13, Number: 3339
< 66,00,00,0D,0B,00,00,00,04,00,00,00,00,
> Type: SSH_FXP_READDIR, Size: 13, Number: 3596
> 0C,00,00,0E,0C,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_NAME, Size: 4723, Number: 3596
< 68,00,00,0E,0C,00,00,00,2A,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 6C,69,6E,75,78,20,20,20,20,20,20,20,20,20,20,20,39,20,53,65,70,20,33,30,20,
< 31,32,3A,32,30,20,66,6F,6F,2E,63,70,70,00,00,00,0F,00,00,00,00,00,00,00,09,
< 00,00,0E,27,00,00,00,C9,00,00,81,A4,41,5B,DE,00,41,5B,DD,EE,00,00,00,0A,69,
> Type: SSH_FXP_READDIR, Size: 13, Number: 3852
> 0C,00,00,0F,0C,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_STATUS, Size: 28, Number: 3852
< 65,00,00,0F,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 00,00,00,
> Type: SSH_FXP_CLOSE, Size: 13, Number: 4100
> 04,00,00,10,04,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_STATUS, Size: 24, Number: 4100
< 65,00,00,10,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
---> that worked fine! now uploading "foo.txt" (which does NOT exist on the server)
. TM: M; ExclM:
> Type: SSH_FXP_OPEN, Size: 54, Number: 4355
> 03,00,00,11,03,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,2F,66,6F,6F,2E,74,78,74,00,00,00,3A,00,00,00,01,00,00,00,00,
> 00,00,00,05,
< Type: SSH_FXP_STATUS, Size: 24, Number: 4355
< 65,00,00,11,03,00,00,00,04,00,00,00,07,46,61,69,6C,75,72,65,00,00,00,00,
< Status/error code: 4, Message: 4355, Server: Failure, Language:
> Type: SSH_FXP_LSTAT, Size: 38, Number: 4615
> 07,00,00,12,07,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
< Type: SSH_FXP_STATUS, Size: 29, Number: 4615
< 65,00,00,12,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 00,00,00,00,
< Status/error code: 2, Message: 4615, Server: No such file, Language:
* Error code: 4
* Request code: 3
. Asking user:
. Cannot create remote file '/linux/home/linux/jaw/foo.txt'. ("General failure (server should provide error description).
. Error code: 4
. Error message from server: Failure
. Request code: 3")
---> failure.. click retry:
> Type: SSH_FXP_OPEN, Size: 54, Number: 4867
> 03,00,00,13,03,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 00,00,00,05,
< Type: SSH_FXP_STATUS, Size: 24, Number: 4867
< 65,00,00,13,03,00,00,00,04,00,00,00,07,46,61,69,6C,75,72,65,00,00,00,00,
< Status/error code: 4, Message: 4867, Server: Failure, Language:
> Type: SSH_FXP_LSTAT, Size: 38, Number: 5127
> 07,00,00,14,07,00,00,00,1D,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
< Type: SSH_FXP_STATUS, Size: 29, Number: 5127
< 65,00,00,14,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 00,00,00,00,
< Status/error code: 2, Message: 5127, Server: No such file, Language:
* Error code: 4
* Request code: 3
. Asking user:
. Error code: 4
. Request code: 3")
* (EScpSkipFile) Cannot create remote file '/linux/home/linux/jaw/foo.txt'.
* General failure (server should provide error description).
* Error code: 4
* Request code: 3
> Type: SSH_FXP_OPENDIR, Size: 30, Number: 5387
> 0B,00,00,15,0B,00,00,00,15,2F,6C,69,6E,75,78,2F,68,6F,6D,65,2F,6C,69,6E,75,
> 78,2F,6A,61,77,
< Type: SSH_FXP_HANDLE, Size: 13, Number: 5387
< 66,00,00,15,0B,00,00,00,04,00,00,00,00,
> Type: SSH_FXP_READDIR, Size: 13, Number: 5644
> 0C,00,00,16,0C,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_NAME, Size: 4723, Number: 5644
< 68,00,00,16,0C,00,00,00,2A,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
> Type: SSH_FXP_READDIR, Size: 13, Number: 5900
> 0C,00,00,17,0C,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_STATUS, Size: 28, Number: 5900
< 65,00,00,17,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 00,00,00,
> Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
> 04,00,00,18,04,00,00,00,04,00,00,00,00,
< Type: SSH_FXP_STATUS, Size: 24, Number: 6148
< 65,00,00,18,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
---> same error.
And lastly, trying with putty's psftp:
psftp> put c:\foo.cpp
local:c:\foo.cpp => remote:/linux/home/linux/jaw/foo.cpp
psftp> put c:\foo.txt
local:c:\foo.txt => remote:/linux/home/linux/jaw/foo.txt
psftp>
no problems, both files are on the server.
hope this helps!
Jens
Jens
by the way,
pscp works for me regardless if the file exists or not.
and the other thing briefly mentioned above: winscp won't
list the directory if I set the protocol to SCP only.
here's a part from the log:
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$status"
< insgesamt 1252
< drwxr-xr-x 1 jaw linux 4096 30. Sep 12:27 .
< drwxr-xr-x 1 root bin 4096 23. Sep 12:31 ..
< -rw-r--r-- 1 jaw linux 33076 25. Jun 2003 1.zip
< WinSCP: this is end-of-file:0
* (ECommand) Error listing directory '/linux/home/linux/jaw'.
* Unexpected directory listing line 'insgesamt 1252'.
* Invalid rights description 'nsgesamt '
"insgesamt 1252" is simply german for "total 1252" -
should I have gotten the multilanguage version of winscp or
is that only a gui thing? maybe this is my mistake after all..
Jens
I'm confused. If it were not OpenSSH I would suppose some incompatibility. But as it is OpenSSH...
I can see that WinSCP attempts to create new file, which fails. Only difference to PSCP and PSFTP is that WinSCP is using SSH_FXF_EXCL flag which should make the attempt fail if the file does exists. However as it does not exists it should not make any difference. And again it is OpenSSH, and WinSCP is well tested with it.
Anyway please turn off overwrite confirmation in Preferences and try again. With overwrite confirmation off, WinSCP will not use the SSH_FXF_EXCL flag.
BTW: Is this happening only to you or even to other users on the same machine? If it is happening to others as well, can I have a test account on the server?
WinSCP requires english environment for SCP protocol.
