Synchronize-question regarding odd setup
plh
I have a somewhat odd need, that I'm not sure is supported - I hope you can tell me if it is:
I need to do a syncronize from ftp to local via a C# script. I have 2 local folders: Download and Archive. I want to look at contents of Archive to determine which files are downloaded from the ftp, but I want to place the files in the Download-folder. A regular Synchronize would obviously look at contents of Archive and update it with new files - this is not what I need.
I'm running some SSIS packages which move files from Download to Archive when they are loaded, and I don't want to re-download them afterwards. Due to a very large amount of files, I don't want to keep all the files in the Download-folder either, since I'm looping through files located in this folder in various SSIS-packages.
Is the above setup possible through some sneaky FileMask or some other method?
Thanks for any input!
/plh
Re: Synchronize-question regarding odd setup
Use a method Session.SynchronizeDirectories from WinSCP .NET assembly.
https://winscp.net/eng/docs/library_session_synchronizedirectories
Do a regular synchronization against the "Archive" folder.
The method returns SynchronizationResult class that contains a list of downloaded (synchronized) files.
https://winscp.net/eng/docs/library_synchronizationresult
Iterate the list and move the downloaded files to "Download" folder.
See also:
https://winscp.net/eng/docs/library_ssis
plh
Perfect - Thank you!
SynchronizationResult is exactly what I needed (and hadn't found).
Seems to work like a charm with the testing I've done so far.
/plh
