WinSCP cannot negotiate a secure key exchange with OpenSSH 6.9 (Fixed in PuTTY 0.65)
marcan
WinSCP supports the following key exchange mechanisms:
diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,rsa2048-sha256,rsa1024-sha1
While OpenSSH 6.9 supports these by default:
curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1
Which means that the following are common:
However, WinSCP is still using the old SSH2_MSG_KEX_DH_GEX_REQUEST_OLD message. Support for the old deprecated message was removed in OpenSSH 6.9:
compat.c Revision 1.90, Mon Apr 13 02:04:08 2015 UTC (2 months, 3 weeks ago) by djm
Branch: MAIN
deprecate ancient, pre-RFC4419 and undocumented
SSH2_MSG_KEX_DH_GEX_REQUEST_OLD message;
ok markus@ deraadt@ "seems reasonable" dtucker@
Which means that WinSCP cannot successfully negotiate diffie-hellman-group-exchange-* ciphers. For this reason, they were blacklisted for WinSCP clients in OpenSSH 6.9:
compat.c Revision 1.92, Tue May 5 10:17:49 2015 UTC (2 months ago) by dtucker
Branch: MAIN
WinSCP doesn't implement RFC4419 DH-GEX so flag it so we don't offer that
KEX method.  ok markus@
This leaves WinSCP with diffie-hellman-group14-sha1. SHA-1 is deprecated and insecure, and security-conscious SSH server administrators disable SHA-1 key exchange mechanisms. WinSCP can no longer negotiate any key exchange mechanism with OpenSSH 6.9 that is considered secure.
PuTTY 0.65 supports the newer message type. Additionally, PuTTY snapshots support newer protocols like curve25519 kex and the chacha20 cipher, which are a really good idea. WinSCP should update to at least 0.65, and the WinSCP team should notify the OpenSSH developers of the minimum version number that will support the new message type, so they can limit the blacklist to older versions.
Re: WinSCP cannot negotiate a secure key exchange with OpenSSH 6.9 (Fixed in PuTTY 0.65)
Thanks for your message.
We will look into this.
mvs
+1 for this!
Can't connect from Far Manager Netbox plugin (based on latest WinSCP) to server with recent OpenSSH 6.9 but successfully connect to it from latest beta PuTTY.
Woitek
problem persists in WinSCP 5.7.5
as far as I understand, the problem is fixed in PuTTY 0.65, and therefore only in non-leased-yet WinSCP 5.8. I guess the information in (https://winscp.net/tracker/1345) is misleading, because it says that the problem has been fixed in WinSCP version 5.7.5.
When is the 5.8 version due to be released?
Wojtek
mvs
@martin, latest WinSCP 5.7.5 (Build 5665) still get error "Couldn't agree a host key algorithm (available: ssh-ed25519)" when trying to connect to server with OpenSSH_6.9p1.
Woitek
Re: problem persists in WinSCP 5.7.5
Hello again, @martin,
whatever it is that has been corrected in 5.7.5, the error that was mentioned earlier (problem connecting to OpenSSH 6.9) still persists:
and as has been written somewhere, the problem is in PuTTY, and has been fixed in PuTTY version 0.65, so until WinSCP moves to PuTTY 0.65 code, it probably won't work. I've read, that WinSCP v5.8 will be based on PuTTY 0.65.
So, back to my question – when is WinSCP 5.8 going to be released? Or is this bug going to be fixed in an earlier version of WinSCP?
Best regards,
Wojtek
Re: log files....
@Omyl: Your server offers only curve25519-sha256@libssh.org KEX to WinSCP.
It's probably because OpenSSH 6.9 (yours) and 7.0 won't offer DH KEX to WinSCP, as OpenSSH since 6.9 dropped support for pre-RFC4419 implementations.
OpenSSH 7.1 will offer DH KEX to WinSCP 5.7.5 and newer (which supports RFC4419). So please upgrade your OpenSSH to the latest version.
mvs
Re: log files....
"OpenSSH_7.1p1, without OpenSSL" – the same error
Couldn't agree a key exchange algorithm (available: curve25519-sha256@libssh.org)
Re: log files....
@mvs: Did you use the latest version of WinSCP (5.7.5)?
Can I have a test account on the server?
Woitek
Hello @martin, sorry for the late reply. I attach the log file, both from WinSCP (as you instructed), and from the OpenSSH server (run in debug mode), both in one file, zipped.
