Weird issue with an uploading from a network mapped folder
montonero
I've got a weird issue with an uploading to FTP from a network mapped folder after upgrading WinSCP from version 4.3.2 to 5.7.4.
There is a network mapped folder "Q:\folder1\folder2\folder3\folder 4" with files "file1" and "file2" (names are example).
The command like this (executed through a script or manually in a console window):
put "Q:\folder1\folder2\folder3\folder 4" "./path_on_ftp/" -resume
works in a strange way: on first call it creates "folder 4" on the target FTP path then throws an error
File or folder 'Q:\folder1\folder2\folder3\folder 4\file1' does not exist.
A call to an OS function failed
On second call it uploads file1 and throws the similar error about file2. On third call it uploads file2.
The same errors shows in the log file (without any additional details).
Uploading of the same files and folders from a local drive works flawlessly.
This error didn't occur in 4.3.2.
Re: Weird issue with an uploading from a network mapped folder
A log file from 4.3.2 for a comparison would help too.
Thanks for the logs.
montonero
Sorry for the delay.
I was finally able to test a debug version and it working without errors.
Just in case I've tried fresh 5.7.5 version - it still fails.
Sent you the debug logs.
