Transfer multiple files
Re: transfer multiple files
diane wrote:
What is the Mark menu and explorer interface only brings up the host not my local directory so I can not transfer files this way.
What about using drag&drop as in Windows Explorer? If you do not like this, use Commander interface, which is intended to be controlled via keyboard.
diane wrote:
Ok I found Mark, but if there are multiple files and we want to select 2 out of three files how do we select only those 2 files?
If you are using Explorer interface, use the same way as you select multiple file in Windows Explorer. For example by holding down Shift or Ctrl keys while clicking mouse buttons.
