Error Code: 5 - Error deleting file 'abc.xml'
Yolaine
I got an error code 5 in the synchronization moving XML files from SFTP server to another location.It used to work fine. I have been able to manually move and delete the files except the file that was the oldest created, which means it's the file that was causing the whole transfer to fail. When I try to delete the file .I get the error:5 (badly formatted packet or protocal incomptability).
I have tried to rename it hoping to be able to delete it but it did not help.
Please any help on how to delete the file will be much appreciated .
Thanks,
Yolaine
Re: Error Code: 5 - Error deleting file 'abc.xml'
