Search on "file changed after" mask problem
victor50
Amsterdam NL
On a Synology NAS (DSM) I wanted to search from root for all files changed the last day. I tried various masks but the search results seem to include files with all kind of change-dates (didn't wait for completion) The mask to exclude small files seems to work.
>2015-07-05;>5K
*>1D; >5K | /volume1/
Re: Search on "file changed after" mask problem
The *>1D is the correct mask to use. But if you want to combine that with a size constraint, it's *>1D>5K.
The *>1D; >5K means all files modified in the last day or larger than 5 KB.
