Can't see a file
ilkevinli
Can't see a file
I am using WinSCP 5.7.4 in commander style using SCP to connect to my NAS device as root. There is a log file in a folder with the name of .ui_info
For some reason, I can't see the file. If I connect using putty, I can see and edit the file.
Is there a way I view the file using WinSCP ? Thanks.
manojvala
Can't see a file from GUI
I was use java code to upload file using FTP.
But using winSCP GUI i cannot view file at root directory.
Re: Can't see a file from GUI
Your duplicate post at Stack Overflow:
