Passing hostkey (sftp) as environment variable is not possible in batch scripting
mwweb15
Hello
i would like to pass the hostkey through environment variable in batch scripting, like it is explained in
https://winscp.net/eng/docs/guide_protecting_credentials_for_automation
for passing the user/password-credentials ("Using WinSCP scripting")
The following line in example script (example.txt) does not work
open sFtp://%PAR_1%:%PAR_2%@IP:Port/ -hostkey=%PAR_3%
open sFtp://%PAR_1%:%PAR_2%@IP:Port/ -hostkey="%PAR_3%" does not work either
The credentials and the hostkey are set as environment-variables (PAR_1, PAR_2, PAR_3) before the script is executed.
It seems that the environment variable for the hostkey is not resolved but the user and password variables are resolved.
Does anybody no if there is a way to pass the hostkey?
The Version of Winscp.exe is 5.7.4.5553
Re: Passing hostkey (sftp) as environment variable is not possible in batch scripting
The environment variables are resolved even before the command is parsed. So there cannot be a difference when using environment variable for host key and username.
You indeed have to enclose the hostkey to double-quotes, as the fingerprint usually contains spaces.
Also show us your batch file.
mwweb15
Answer (SOLVED)
Thanks for your hints. I found the problem, sorry it was my fault.
The environment variable %PAR_3% was not set correctly in the batchfile, sorry.
The following command in the script works perfect, the hostkey is resolved correctly
Regards
