Terminated by User error and check for functionality
Parag Bangar
India
We are using the WinScp dll with one of our .Net application for Moving/Putting/Deleting the files from specific servers.
I would appreciate to have the prompt response to below two queries:
1. At a few times a day it sends us "Terminated by User" error.
FYI, one instance of connection is being closed before creating the new one for next task.
There is nothing with code i feel here, something related to WinScp utility itself is aborting this.
What could be the reason and is there any way to track/debug the same ?
2. Is there any way from where we can list out the latest files from a directory ? Currently we are using RemoteDirectoryInfo.GetListOfFiles() which provides us all the files from a particular directory but I want to list out those which are new ones i.e. uploaded on the directory in last 3 days.
Let me know your suggestions on the same.
Thanks in Advance.
Parag Bangar
E : parag.bangar@ge.com
M : +91-7600701624
Re: Terminated by User error and check for functionality
There's no RemoteDirectoryInfo.GetListOfFiles.
How to filter the file list depends on a language you are using.
Parag Bangar
India
We just have to provide the path of the blank text file where we want the logs , right?
We are using Ftp methods of winscp.dll with C# code.
Below is the function which provides the list of the files from a particular Ftp location.
What i want is : get the latest uploaded files from this location instead of getting all the files residing there.
public static RemoteDirectoryInfo GetListOfFiles()
try
RemoteDirectoryInfo remoteDirectory;
SessionOptions sessionOptions = new SessionOptions();
sessionOptions.Protocol = Protocol.Sftp;
sessionOptions.HostName = strPickupFTPHost;
sessionOptions.UserName = strPickupFTPUserName;
sessionOptions.Password = strPickupFTPPassword;
sessionOptions.PortNumber = intPickupPortNumber;
sessionOptions.SshHostKeyFingerprint = strPickupSshHostKey;
if (sessionOptions.Password == null || sessionOptions.Password == "")
sessionOptions.SshPrivateKeyPath = strPickUpSshPrivateKeyPath;
session.Open(sessionOptions);
remoteDirectory = session.ListDirectory(clsUtility.strFilePickupLocation);
session.Dispose();
return remoteDirectory;
The file does not need to exist.
try
session.Dispose();
In C# use:
IEnumerable<RemoteFileInfo> lastestFiles = dir.Files.Where(file => file.LastWriteTime > DateTime.Now - TimeSpan.FromDays(3));
