Large file = different editor?
Is it currently possible / something that could be added, where you can define which editor to use, when files are different sizes?
Generally I use SubLime as my editor for programming. However, it doesn't do well on large SQL/log files (and sometimes crashes).
what would be great, is that I could set it to that anything greater than say 5Mb would open in something that handles it better (i.e doesn't try and process it with a syntax highlighter)
Is this possible?
TIA
Andy
Is this possible?
TIA
Andy
