How to properly delete remote directory using .NET library
mmedic
USA
I have tried using Session.RemoveFiles with and without a trailing slash but without success. Operation succeeds but the RemovalOptionResult shows 0 removals. I have verified that the directory exists on the remote server. It does contain [] (brackets) in the name. I am not sure if that causes any issues.
mmedic
USA
I assume you meant to say "Session.RemoveFiles should not remove the directory with [at least one] file [in it]." My directory is indeed empty but once the command is executed it reports that there was no match found.
In any event, how does not remove a directory (empty or not)? I downloaded the source code and created a method RemoveDirectory which calls
rmdir -- "dir_name"
and that works but the original library does not seem to provide this functionality. I am missing something?
Re: How to properly delete remote directory using .NET library
