winscp.com attempting to automate upload from c:\windows\system32\certsrv\certenroll\
cs_280zx
Sydney
Hi, we have two 2012 R2 servers with WinSCP (GUI client) installed (version: 5.7.4 - build 5553) and we have scripted it to attempt to upload files from the server where the WinSCP is installed, to two web servers.
I have tested the script and it does work from a (different directory) and on another PC (Windows 8.1) but for some reason, it won't put files referenced from that directory. Any suggestions or steps I am missing? I searched around and wasn't able to find anything like my situation.
ps: it's used to upload crl's for our pki servers as part of the 2012 PKI infrastructure here.
Script launch parameters:
c:\Program Files (x86)\WinSCP>winscp.com /script=c:\scripts\crl_transfer_pki.txt
Script layout:
# This script uploades the newly created CRLs To the PKI servers And overwrites existing files On the PKI Hosts
option batch abort
# Connect to SFTP server PKI-01 using a password
open sftp://xxxxxxxx:xxxxx@xxxxx.replaceme.com.au/ -hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
# Change remote directory *using a temp location*
cd /var/www/html/CertEnroll
# Upload file
put C:\Windows\System32\certsrv\CertEnroll\*.crl
# Disconnect
# Connect to SFTP server PKI-02 using a password
# Upload file
# Disconnect
close
# Exit WinSCP
When run, this is the output:
batch           abort
reconnecttime   120
confirm         off
Searching for host...
Connecting to host...
Authenticating...
Using username "crl".
Authenticated.
Starting the session...
Session started.
Active session: [1] crl@xxxxx.replaceme.com.au
No file matching '*.crl' found. (System Error.  Code: 3.
The system cannot find the path specified)
Authenticating...
Authenticated.
Session started.
Active session: [2] crl@xxxxx.replaceme.com.au
Session 'crl@xxxxx.replaceme.com.au' closed.
I can verify files exist in this directory also, and it was executed in an elevated command prompt, logged in using domain administrator on the 2012 R2 server.
Any suggestions or assistance is appreciated.
thanks
Re: winscp.com attempting to automate upload from c:\windows\system32\certsrv\certenroll\
The C:\Windows\System32 folder is "magic" on 64-bit Windows. It shows a different contents to 32-bit applications (WinSCP) than to 64-bit applications (e.g. Windows Explorer).
To 32-bit application (WinSCP), it shows actually a contents of C:\Windows\SysWOW64, where there's no certsrv subfolder.
There's probably no direct way to access certsrv from WinSCP. You can though create a directory junction to the subfolder to create an alternative access path.
Edit 2021: Actually, there is a hidden C:\Windows\sysnative, which can be used by 32-bit applications like WinSCP to access the 64-bit System32 folder.
cs_280zx
Sydney
Hi, thank you for your suggestion, sorry for the delay many projects to manage at the moment. I will give your suggestions a go on monday and let you know the results.
thanks
carl
cs_280zx
Sydney
Hi there,
I used the command
mklink "c:\scripts\linked\  c:\Windows\System32\certsrv\CertEnrol"
Now I changed the path in the txt file as follows:
# Upload file
put C:\scripts\linked\certenroll\*.crl
# Disconnect
close
# Exit WinSCP
