Simultanious sFTP Transfer Using a Script
The ability to have WInSCP transfer multiple files simultaneously using a queue similar to the GUI would be helpful. Version 5.7.1 does not appear to support background transfer from a script.
Sample script I am currently using:
option batch abort
open sftp://%sFTP-UID%:%sFTP-Pwd%@%DestServer%
option echo on
cd "%UploadRemoteFolder%"
put "*.bak"
close
option batch abort
option echo on
put "*.bak"
close
