Custom Commands - insertering date
VelvetJones
Hi, I've made a custom command that makes a backup copy of the file in question. Is there anyway to have it append the file with the date for example:
test.txt
would get a backup copy
test.txt.20040924
Your response is greatly appreciated.
James
Re: Custom Commands - insertering date
WinSCP cannot do this, but you probably can achive the same result using shell function.
Something like following command can help:
cp ! /backup/!`date +%Y%m%d`
