winscp put -delete problem
pcolina
Hi everyone,
I'm trying to upload some files to a remote server using a winscp script with deletion of the file uploaded, but instead of just deleting the files, it deletes all directory.
Could you tell me where is my mistake?
My script looks like:
put -delete "C:\TEMP\Out\" /targetFolder/
close
After finishing the process, the files content has been uploaded, but the Folder "out" (with all its content) has been also deleted.
Can anyone help me?
Re: winscp put -delete problem
You are uploading folder Out, right? The Out is moved to the remote directory (/targetFolder/Out is created). So Out is also removed.
If you want to move just files, use
put -delete "C:\TEMP\Out\*" /targetFolder/
