WinSCPnet.dll on Windows 2000
Bartman
Drancy, France
Hi
I'm developing an SFTP interface using WinSCP and WinSCPnet.dll release 5.7.3. This GUI has to run on Windows 2000 server.
Unfortunately, this release seems not to work on W2K server.
I get this error:
WinSCP process terminated with exit code 0 and output "", without responding (response log file C:\Documents and Settings\XXXXXX\Local Settings\Temp\wscp1178.03CE0BB8.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
Which release have I to use?
Thanks.
Bartman
Drancy, France
WinSCPnet.dll on Windows2000
Hi...
Sorry for the delay...
The code should run under Windows 2000 Server SP4.
This code works fine on my Windows 7 developer machine, using last bin and dll of WinSCP.
Have try to use older release of WinSCP... no success.
Regards.
Re: WinSCPnet.dll on Windows2000
Can you run WinSCP GUI on the system? Can you run WinSCP in scripting mode? winscp.exe /console?
soggi
soggi avatar
soggi.org
Just in case anyone needs the answer to this issue:
Bartman wrote:
Hi
The last release which works on Windows 2000 is version WinSCP 5.1.8 which is available from my website (https://soggi.org/misc/tools.htm) or from SourceForge (https://sourceforge.net/projects/winscp/files/WinSCP/).
kind regards
soggi
_________________
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches
-> soggi's BIOS & Firmware Page
