Task Scheduler Not Working Well
itzsnider
Okay so I am trying to sftp to my server, grab all files in the directory, and then put them into my OneDrive folder locally.
What am I missing?
/command "open sftp://username:pwd@hostname/" "cd /epic/prdfiles/foundations/auditreports" "get -r *" "put C:\Users\USER\OneDrive\Auditing\Data Courier\POC to REL" "exit"[/m]
Re: Task Scheduler Not Working Well
I assume you wanted to do:
... "get * ""C:\Users\USER\OneDrive\Auditing\Data Courier\POC to REL\""" ...
Note that there's no -r switch to get (it's recursive implicitly)
To debug this, wrap the winscp.com call to a batch file and redirect its output to a file:
winscp.com /command .... > c:\path\winscp.out
And reference the batch file in Scheduler, instead of the WinSCP.
Try to run and inspect the winscp.out.
Make sure the scheduler account has a write access to the path.
