Convert to Powershell - SynchronizeDirectories Almost there.
shcsbaker
trying to convert a batch synchronize file to PowerShell and not sure how to convert the resumesupport switch.
I use a script file and it looks like this:
open sftp://username:password@myftp.com / -hostkey="host key"
synchronize remote -criteria=size -resumesupport=on -delete U:\ /folderA
synchronize remote -criteria=size -resumesupport=on -delete T:\ /folderB
close
Here's what I have so far in my Powershell:
# Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
 # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::sftp
    $sessionOptions.HostName = "myftp.com"
    $sessionOptions.UserName = "username"
    $sessionOptions.Password = "password"
    $sessionOptions.SshHostKeyFingerprint = "ssh info"
# Connect
# Synchronize Files
    $session.[WinSCP.TransferResumeSupportState]::On
    $synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote,"U:\", "/folderA/", $True)
    $synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote,"T:\", "/folderB/", $True)
# Disconnect, clean up
    $session.Dispose()
Again looking for help converting the resumesupport switch and to ensure I've got the rest of the PowerShell script correct.
Thanks,
Kevin
Re: Convert to Powershell - SynchronizeDirectories Almost there.
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::On
$synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote,"U:\", "/folderA/", $True, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
$synchronizationResult.Check()
$synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote,"T:\", "/folderB/", $True, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
See https://winscp.net/eng/docs/library_from_script_transfer_settings
