Server sent passive reply with unroutable address, using host address instead | Could not retrieve
Dear all,
I would like to say thank you everyone who supports WinSCP. I really love it. But it appears one issue that I could not still resolve.
I'm using last available version of WinSCP.
I have simple script to get files:
option batch continue
open ftp://login:password@ip:port -passive=on
lcd \\localserver\folder$
cd /ftpfolder/folder
synchronize local
And I receiving following errors:
TLS connection established. Waiting for welcome message...
Connected
Starting the session...
Session started.
Active session
/ftpfolder/folder
Comparing...
Local '\\localserver\folder$\2014\12' <= Remote '/ftpfolder/folder/2014/12'
Error listing directory '/ftpfolder/folder/2014/12'.
Server sent passive reply with unroutable address IP, using host address instead.
Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
I tried to use WinSCP GUI and there is the same error.
Using host address IP instead of the one suggested by the server: IP2
Timeout detected. (data connection)
At the same time it works fine with FileZilla:
Command: PASV
Command: USER USER
Status: TLS/SSL connection established.
Response: 331 Password required for LOGIN.
Command: PASS *********
Response: 227 Entering Passive Mode (ip,195,87).
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: LIST
Response: 150 Opening BINARY mode data connection.
Response: 230 User logged in.
Command: OPTS UTF8 ON
Response: 200 OPTS UTF8 command successful - UTF8 encoding now ON.
Command: PBSZ 0
Response: 200 PBSZ command successful.
Command: PROT P
Status: Verifying certificate...
Response: 200 PROT command successful.
Status: Connected
Command: USER USER
Status: Starting download of /folder/folder/2014/12/31/file.txt
Command: CWD /folder/folder/2014/12/31
Response: 331 Password required for USER.
Response: 250 CWD command successful.
Command: PWD
Response: 257 “/folder/folder/2014/12/31" is current directory.
Command: TYPE I
Response: 200 Type set to I.
Command: PASV
Command: PBSZ 0
Command: PROT P
Response: 227 Entering Passive Mode (ip).
Command: RETR file.txt
Status: Connected
I saw there the same error in in the FileZilla:
"Server sent passive reply with unroutable address. Using server address instead"
but it works and copy files successfully.
I tried to use FTP and FTPS and it works for FileZilla but failed with WinSCP.
Not sure if there any additional setting that I need to put for WinSCP to get this resolved.
BTW I increased timeout but this did not help.
Thank you in advance for your help,
Re: Server sent passive reply with unroutable address, using host address instead | Could not retrieve
Please attach a complete log file both from WinSCP and FileZilla. Please do not obfuscate the IP addresses, otherwise it's pointless. They are important for this particular issue.
