environmental problem running command via terminal window
Alexey
Hi
I succesfully login to my acoount on FreeBSD machine. But when I open Terminal/Console window and issue 'env' command I don't see enviroment variables that have to be set in .bashrc file.
I want to run a bash script which uses some environment configured in .bashrc.
What could be a problem? Are there any workarounds?
Thanks,
Alexey
Re: environmental problem running command via terminal window
Some of the startup scripts are not executed for non-interactive sessions. Try to set your variables in other scripts (like .profile, .bash_profile, etc.)
aphongka
Strange, but non of the files seems to work :( neither .bashrc, nor .bash_profile, nor .profile, nor .cshrc, nor /etc/profile. Are there any other ways to set up the environment while running a script?
Reply with quote E-mail
Strange. Another hint: some variables are unset by WinSCP on start up. Maybe the one you need is among them. These variables are: LANG, LANGUAGE, LC_CTYPE, LC_COLLATE, LC_MONETARY, LC_NUMERIC, LC_TIME, LC_MESSAGES, LC_ALL, HUMAN_BLOCKS. You may uncheck the "clean national variables" on SCP tab of login window to avoid this. But WinSCP may not work then,
aphongka
No, I setup PATH, LANG and some application specific variables.
Well when i use ssh from cigwin environment like
ssh -l user host.com env|sort
i see that .bashrc has run. The command like this
$>env|sort
shows that .bash_profile has run
But nothing has run with WinSCP. What is the problem? Is it a bug or a feature?
Can you try to add -T option to ssh command and check what, if any, script is executed? With -T option, 'ssh' should use then the same mode as WinSCP.
aphongka
first variant of ssh (non interactive) works with -T option too (I mean .bashrc is run)
second variant (interactive) hangs with -T option and I am not able to see if it works
I'm sorry, but I've runned out of ideas. I just works for me fine :-(
