Erreur Synchro UTF8 Directory
Rlooping
France
Since version 5.7.3 .NET assembly, I can not synchronize directories with accents in French.
My setup:
   Dim As New mySessionOptions sessionoptions
   with mySessionOptions
     .protocol = Protocol.Scp
     .HostName = Syncros.SSHHostName
     .UserName = Syncros.SSHUserName
     .PortNumber = Syncros.SSHPort
     .SshPrivateKeyPath = Syncros.SshPrivateKeyPath
     .GiveUpSecurityAndAcceptAnySshHostKey = True
     .AddRawSettings ("UTF", "2")
   End With
I also tried with: .AddRawSettings ("Utf", "1")
I get an error:
Copying file '/ home / xxx / xxx / Param trage' failed.
"Param trage" for "Paramétrage"
Re: Erreur Synchro UTF8 Directory
