WinSCP + Task scheduler
DocSpencer
Hello everyone,
I'm trying to upload some files every xx hours from a server to another ftp using the windows task scheduler.
I made the task as shown in https://winscp.net/eng/docs/guide_schedule but all i get is a 0x1
I used the arguments:
/command "option batch abort" "option confirm off" "open -explicittls ftp://user: password@server.de:21" "/log=C:\log\winscplog.txt" "put c:\Verzeichnis\*.xml /" "exit"
So, the log file says the connection is ok, but the file wasn't uploaded... :(
Anyone an idea??
Doc
Re: WinSCP + Task scheduler
Where did you take the command-line from?
This problem repeats far too often, so I'd really like to find out where do people take this wrong syntax from.
