Automatic file downloads?
emoran
is there any way to get this up to automagically grab a set of files from a site, and remove them from said site without any user interaction?
i.kennedy@...
Re: Automatic file downloads?
In the next version...
Hi can you tell me if this is now possible I noticed from the reply this was in 2002 I have just recently downloaded winscp Version 3.6.1 build 221
your hopeful
Irene
The reply is one week old "16 Sep 2004 07:24" :-) I'm working on it.
Any luck on this? I would like to be able to use Windows task scheduler to start a winscp3 session and upload some files to a remote site in the background automatically without user intervention. 3.7 suggests that this is doable but I haven't been able to get it to work.
Jay McDonald
jay@forecasttech.com
Why? What's the problem?
