No Constructor for WinSCP.TransferResumeSupport
dotps1
Contributor
United States
I was working with the [WinSCP.TransferOptions] Class, i wanted to set the .ResumeSupport property. I see that that property should be of Type WinSCP.TransferResumeSupport. Which has two properties, State and Threshold, so this was my goal:
$resumeSupport = New-Object -TypeName WinSCP.TransferResumeSupport
$resumeSupport.State = 'On'
$resumeSupport.Threshold = 1000
$transferOptions = New-Object -TypeName WinSCP.TransferOptions
$transferOptions.ResumeSupport = $resumeSupport
However, for the first line i get the following error:
New-Object : A constructor was not found. Cannot find an appropriate constructor for type WinSCP.TransferResumeSupport.
I know this can be done:
$transferOptions.ResumeSupport.State = 'On'
$transferOptions.ResumeSupport.Threshold = 1000
But i would like to be able to declare my TransferResumeSupport Object separately. Is there a reason there is no constructor for this object type?
Re: No Constructor for WinSCP.TransferResumeSupport
The reason is that you do not need to declare the TransferResumeSupport object separately.
What do you need it for?
dotps1
Contributor
United States
I guess i don't really 'Need' it per say. Its just that the WinSCP.TransferOptions.ResumeSupport takes an object of Type TransferResumeSupport, So i thought i should be able to create that object, set its properties, and then use it when configuring the WinSCP.TransferOptions Object.
https://github.com/tomohulk/WinSCP/issues/9
lmo
There is a setter
#region Assembly WinSCPnet, Version=1.3.4.6885, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf
// G:\S\SingleServe\MAIN\Library\WinScp\WinSCPnet.dll
#endregion
using System.Runtime.InteropServices;
namespace WinSCP
[ClassInterface(ClassInterfaceType.AutoDispatch)]
[ComVisible(true)]
[Guid("155B841F-39D4-40C8-BA87-C79675E14CE3")]
public sealed class TransferOptions
public TransferOptions();
public string FileMask { get; set; }
public FilePermissions FilePermissions { get; set; }
public OverwriteMode OverwriteMode { get; set; }
public bool PreserveTimestamp { get; set; }
public TransferResumeSupport ResumeSupport { get; set; }
public int SpeedLimit { get; set; }
public TransferMode TransferMode { get; set; }
Re: There is a setter
#endregion
namespace WinSCP
[ComVisible(true)]
Yes, but only since WinSCP 5.8.2. This thread is old and obsolete.
