VBA Error while setting the permissions and/or timestamp
dodonohoe
Hi all,
I am getting the above error despite having selected the "ignore permissions errors on the console". The result is that of the ten folders I am trying to transfer it transfers one and then stops on the first file. I have read of command options using VB (Setting preserve time stamp option to false) and was wondering if there is something I can add to the code below (VBA) to prevent this error and allow my files/folders to be transferred.
Here is the full code I am using
Option Explicit
Sub VariableFTP()
    Dim mySession As New Session
    ' Enable custom error handling
    Upload mySession
    ' Query for errors
    If Err.Number <> 0 Then
        MsgBox "Error: " & Err.Description
        ' Clear the error
        Err.Clear
    End If
    ' Disconnect, clean up
    mySession.Dispose
    ' Restore default error handling
    On Error GoTo 0
End Sub
Private Sub Upload(ByRef mySession As Session)
    ''this is where we create a variable that allows our filepath _
    to change
    Dim FilePathx As String
    Dim FilePathY As String
    Dim FilePathz As String
    Dim FundName As String
    Dim Datex As String
    Sheets("Paperless Checklist ").Select
    FundName = Range("B6")
    Sheets("Variables").Select
     Datex = Range("B46")
    'FilePathx = Range("B22") & "\*"
    FilePathx = Range("B22") & "\"
    FilePathz = "/Usr/dubtrustee/"
    FilePathY = FilePathz & "/" & FundName & " " & Datex
    'FilePathx = Range("c2") & "\*"
    'FilePathY = Range("c4")
    ''check to see if the source filepath (filepathx)exists
    If Len(Dir(FilePathx, vbDirectory)) = 0 Then
    MsgBox "The Source File Path does not exist. Please check this file path.", vbCritical
    Exit Sub
    Else
    End If
    ''check to see if the source filepath (filepathx) actually contains files
    If Dir(FilePathx & "*.*") = "" Then
        MsgBox "The Source File Path does not contain any files. Please copy your client reports into this file path.", vbCritical
        Exit Sub
    Else
    Dim mySessionOptions As New SessionOptions
    With mySessionOptions
        .Protocol = Protocol_Sftp
        .HostName = "**********"
        .UserName = "******"
        .Password = "*********"
        .SshHostKeyFingerprint = "*************************************"
    End With
    ' Connect
    mySession.Open mySessionOptions
    ' Upload files
    Dim myTransferOptions As New TransferOptions
    myTransferOptions.TransferMode = TransferMode_Binary
    Dim transferResult As TransferOperationResult
    'we use this line if we want to take just the files not the folder
    'Set transferResult = mySession.PutFiles(FilePathx, "/Usr/sebprime/", False, myTransferOptions)
     Set transferResult = mySession.PutFiles(FilePathx, FilePathY, False, myTransferOptions)
    ' Throw on any error
    transferResult.Check
    MsgBox "Transfer Successful", vbInformation
    End If
End Sub
Re: VBA Error while setting the permissions and/or timestamp
