Open session and log connection details
Hi all, I'm trying to troubleshoot a session opening which gives me the following error:
"Message: Terminated by user.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)"
The code I'm running is the following:
Am I missing something here?
I believe that enclosing all code inside using it closes and disposes the connection.
After this error I was able to upload files to server correctly. is there any way to enable and use WinScp logging to trace connection issues?
Thank you.
SessionOptions sessionOptions = new SessionOptions(); sessionOptions.Protocol = Protocol.Sftp; sessionOptions.HostName = "sftp.stuff.com"; sessionOptions.UserName = "username"; sessionOptions.Password = "password"; sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true; using (Session session = new Session()) { session.Open(sessionOptions); TransferOptions transferOptions = new TransferOptions(); transferOptions.TransferMode = TransferMode.Binary; transferOptions.PreserveTimestamp = false; TransferOperationResult transferResult; transferResult = session.PutFiles("C:\localfile.txt", "sftp.stuff.com/remotepath/remotefile.txt", false, transferOptions); transferResult.Check(); }
Thank you.
