WinSCP - Loading Problem Files with Dateformat Special Characters
pipo2
I have an interesting one here.
When login in via FTP I am only able to see the folders shop1, however not shop_test, webalizer and 2014a. From the log it looks like a special character issue for the date of a file. So in this case it should be Mär, but Mär is shown. No problem using other ftp clients, it works great, but only WinSCP has problems here. Do you know what that could be or how I can solve it?
. 2015-05-11 11:22:45.905 Connecting to xxx.x.xxx.xx:xxxx ...
< 2015-05-11 11:22:46.055 150 Opening ASCII mode data connection for /bin/ls.
. 2015-05-11 11:22:46.194 insgesamt 56
. 2015-05-11 11:22:46.194 drwxrwx--- 12 www-data safer 4096 8. Mai 07:50 .
. 2015-05-11 11:22:46.194 drwxrws--- 14 www-data safer 4096 19. Mär 15:11 2014a
. 2015-05-11 11:22:46.194 drwxrwx--- 3 www-data safer 4096 11. Nov 20:17 shop1
. 2015-05-11 11:22:46.194 drwxrwx--- 3 www-data safer 4096 6. Mär 13:29 shop_test
. 2015-05-11 11:22:46.194 drwxrwx--- 2 www-data safer 4096 3. Mär 2011 webalizer
Re: WinSCP - Loading Problem Files with Dateformat Special Characters
pipo2
Attached (private only).
PostWinSCP - Loading Problem Files with Dateformat Special Characters
[Reply with quote] [Edit this post]
  • winscp.log (10.31 KB, Private file)
pipo2
Try to set UTF-8 encoding for filenames session option to On.
https://winscp.net/eng/docs/ui_login_environment
I entered UTF-8 ON to force it however it still does not work. The issue is not special characters in the filename from what i see, but the date format of the files ... file creation date with special characters, so called Umlaute (in German).
Please attach a full log file with UTF-8 set to On.
WinSCP should recognize the "Mär".
pipo2
See enclosed full log
  • logwithutfforcedon.log (8.53 KB, Private file)
pipo2
I have uploaded the logs for you.
What I have noticed is following.
> 2015-05-13 13:15:19.819 FEAT
< 2015-05-13 13:15:19.859 500 'FEAT': command not understood.
> 2015-05-13 13:15:19.859 OPTS UTF8 ON
< 2015-05-13 13:15:19.894 500 'OPTS UTF8 ON': command not understood.
. 2015-05-13 13:15:19.934 Connected
My Server however supports UTF8
LANG=de_DE.UTF-8
LANGUAGE=de_DE.UTF-8
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC="de_DE.UTF-8"
LC_TIME="de_DE.UTF-8"
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY="de_DE.UTF-8"
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER="de_DE.UTF-8"
LC_NAME="de_DE.UTF-8"
LC_ADDRESS="de_DE.UTF-8"
LC_TELEPHONE="de_DE.UTF-8"
LC_MEASUREMENT="de_DE.UTF-8"
LC_IDENTIFICATION="de_DE.UTF-8"
LC_ALL=
pipo2
LANG=de_DE.UTF-8
LC_ALL=
Any news on the issue?
