parent directory in webdav
user7689
bug occurs in version 5.7.2 build 5316.
when connected to my webdav account at box.com, parent directory ("..") is not listed. Instead, same directory name is there. So if you're in subdirectory named "09-september" you'll see "09-september" instead of "..". Of course, clicking on this (in both panel modes) makes winscp try to go to "09-september\09-september" which will end up as 404 not found. In version 5.6.4 beta this is working just fine (parent dir is showed and working).
Re: parent directory in webdav
