transfere speed for background transfere, trayicon and queue
guest
HI
1. it would be grate if you could get winscp to be minimized to tray so even if you had serval downloads/uploads (and it would be only trayicon no other windowses)
2. queueing, it would be nice if you could queue files so another could start when another gets finished ... and you could set maximum transfer speeds for them so they wouldn't take all bandwidth (before they start)
3. There is no transfer speed in background downloading =(
Still the best ssh client i have used. It's simple, well at least the ie look a like and transfers seems to be going faster than f-secure's product. I always hated when f-secure's ssh popped up at the top of applications and if you had transfer going you really couldn't close it. And if connection was lost there was no resume ... at least not back then when i used it.
Thanks for your time to make us this kind of grate program!!!
Re: transfere speed for background transfere, trayicon and queue
I do not think that WinSCP is the kind of application to be minimised to tray. Anyway there are tens of tools to minimize any application to tray. Get some.
I do not understand. This is how the queue works. You can set maximum number of simultaneous transfers. If you schedule more transfers, the rest will wait until some finishes.
OK, sometime.
You want to display transfer speed in the list?
