directory listing auto expand
rbrooker
victoria university, wellington, NZ
hi, great program.
one suggestion though, when browsing the directory panel, can you make an option for autoexpanding the directory. this way, when you click on a directory, you dont need to explicitly expand the directory to get to the directories below it.
optin for this as there may be directories with many others below them, slow links etc.
cheers.
rich.
_________________
richard.brooker@vuw.ac.nz
Reply with quote E-mail
Re: directory listing auto expand
OK.
Content of directory is loaded just when you click on it, because it is shown on the file panel anyway. So theres no reason to make it optional.
Thanks Martin,
This really is a great program. i know it makes my life a heap easier.
rich.
