Synchronize in .Net assembly and -Preview parameter
BillCumming
Milwaukee
Does the .Net Assembly version of Synchronize support the -preview parameter from the command line version?
I would like to know BEFORE I execute the Synchronize command whether anything has changed (and therefore whether to backup the previous known good version).
Re: Synchronize in .Net assembly and -Preview parameter
No it does not.
If you are using local to remote SFTP synchronization, WinSCP can preserve the original for you:
sessionOptions.AddRawSettings("OverwrittenToRecycleBin", "1");
sessionOptions.AddRawSettings("RecycleBinPath", "/tmp/backup");
BillCumming
Milwaukee
I'm using remote to local SFTP synchronization (local is the backup of a remote server), so I set the following (local is a Win7 64-bit system):
$sessionOptions.AddRawSettings("OverwrittenToRecycleBin", "1");
$sessionOptions.AddRawSettings("RecycleBinPath", "G:\VMServerBackup\testsave");
I ran the synch and 1 modified file was downloaded, but no file appeared in the RecycleBinPath location.
Does this option work for remote to local sync?
If so, I am scripting the backup of multiple directories. Can I change this sessionOptions value between calls to Synchronize, or do I have to close and re-open the session?
Thanks!!
No. That's why I explicitly referred to the "local to remote" synchronization.
BillCumming
OK. Last question: the FileTransferProgress and FileTransferred event handlers and $synchronizationResult.Removals.Count all seem to ignore any files that are removed. Is there a setting that I'm missing?
That's as designed. The SynchronizationResult.Removals reflects removals of remote files only. We may improve this in a feature.
