Issue with VBSCRIPT
Gianluca_Italy
Issue with VBSCRIPT
Good Morning.
I'm trying to automate a connection with FTP site (SSL Explicit enc).
Here below my code
Option Explicit
' Setup session options
Dim sessionOptions, FtpSecure, TlsHostCertificateFingerprint, Explicit, Protocol_ftp
Set sessionOptions = WScript.CreateObject("WinSCP.SessionOptions")
With sessionOptions
.Protocol = Protocol_ftp
.FtpSecure = Explicit
.HostName = "xxxxxx"
.UserName = "xxxxxx"
.Password = "xxxxxx"
End With
Dim session
Set session = WScript.CreateObject("WinSCP.Session")
session.SessionLogPath = "C:\TEMP\TestSessionLog.txt"
session.DebugLogPath = "C:\TEMP\TestDebugLog.txt"
' Connect
session.Open SessionOptions
Const ForReading = 1
Dim fileName, fileName2, remotePath, remotePath2, localPath
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objDictionary = CreateObject("Scripting.Dictionary")
Set objFile = objFSO.OpenTextFile("C:\TEMP\RBC LBX NEXT SEQUENCE.ini", ForReading)
i = 0
Do Until objFile.AtEndOfStream
strNextLine = objFile.Readline
If strNextLine <> "" Then
'fileName = "LBXACN." & strNextLine
'fileName2 = "LBXACN." & strNextLine & ".downloaded%FTPS"
fileName = "pippo"
fileName = "pippo2"
End If
Loop
objFile.Close
'remotePath = "/outbound/HVHV" & fileName
'remotePath2 = "/outbound/HVHV" & fileName2
remotePath = fileName
remotePath2 = fileName2
localPath = "C:\INTERF\UCQ\RBC\LOCKBOX" & fileName
Dim fs
Set fs = WScript.CreateObject("Scripting.FileSystemObject")
Dim download, remoteWriteTime, localWriteTime
If session.FileExists(remotePath) Then
' Download the file and throw on any error
session.GetFiles(remotePath, localPath).Check()
WScript.Echo "Download to C:\INTERF\UCQ\RBC\LOCKBOX\ done."
Else
WScript.Echo "File " & remotePath & " does not exist yet"
End If
If session.FileExists(remotePath2) Then
session.GetFiles(remotePath2, localPath).Check()
Else
WScript.Echo "File " & remotePath2 & " does not exist yet"
End If
' Disconnect, clean up
session.Dispose
The error is
Executing Assembly: WinSCPnet, Version=1.2.7.5235, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf; Path: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WinSCPnet.DLL; Location: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WinSCPnet.dll; Product: 5.7.1.0
Exception: System.ArgumentException: SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.HostKey is not set.
in WinSCP.Session.SessionOptionsToOpenSwitches(SessionOptions sessionOptions)
in WinSCP.Session.SessionOptionsToOpenCommand(SessionOptions sessionOptions, String& command, String& log)
in WinSCP.Session.Open(SessionOptions sessionOptions)
Thanks in advance for your support.
Re: Issue with VBSCRIPT
Please attach a full session and debug log files showing the problem (using the latest version of WinSCP).
Set Session.SessionLogPath and Session.DebugLogPath. If you do not want to post the logs publicly, you can mark the attachments as private.
Also attach your complete WSF file.
In attachment
  • TestDebugLog.txt (13.59 KB, Private file)
  • TEST_FTP.txt (1.68 KB, Private file)
Description: WSF file
Only now I noticed that you declare these variables:
Dim ..., FtpSecure, TlsHostCertificateFingerprint, Explicit, Protocol_ftp
They obviously shadow the constants/symbols from WinSCP .NET assembly. You have to remove that declaration.
Many Thanks !!!
It works.
Can I ask you another information about session.MoveFile ?
Is it possibile to move files from remote path to another remote path (for example from /temp to /test) ? Both paths are on the same FTP site.
Good evening.
I'm not able to use wsf because i've this error :
Version of C:\INTERF\jobs\Scripts\winscp\winscp.exe is 5.1.6.3394, product WinSCP version is 5.1.6.0
[2015-05-06 22:11:46.299Z] [0001] Exception: WinSCP.SessionLocalException: The version of C:\INTERF\jobs\Scripts\winscp\winscp.exe (5.1.6.0) does not match version of this assembly C:\INTERF\jobs\Scripts\winscp\WinSCPnet.DLL (5.7.1.0). You can disable this check using Session.DisableVersionCheck (not recommended).
I tried with
session.DisableVersionCheck = true
without success :-(
Anonymous wrote:
Good evening.
So why don't you get same version of both files?
