Sample Script to send files using SFTP WINSCP
vk.kumar
INDIA
Hi All,
Iam new to scripting. My requirement is as below:
Poll the files from a particular location and send to target location using SFTP (WINSCP).
Guide me writing a script for this requirement.
Thanks in Advance.
Krishna
Re: Sample Script to send files using SFTP WINSCP
What specific problem are you having with the task? Where are you polling the files from? A local or remote location?
vk.kumar
INDIA
1. Files will be polled from local machine.
2. I need to transfer multiple files from local machine to remote SFTP location.
Could you provide sample script for the above requirement.
vk.kumar
INDIA
Thanks for the update.
what should be given in the hostkey value.
open sftp://user:password@example.com/ -hostkey=""
Hema
Navigation to find -host key fingerprint
If you are using 5.7.2. version, click 'Session' tab in the Menu, then click 'Server/Protocol Information'. 'Server host key fingerprint' can be seen at the bottom of the 'Protocol' screen.
vk.kumar
INDIA
thanks for update.
we are using WINSCP 4.3.2 version. I couldn't able to find the option which you were telling.
do we need to give the private key in the hostkey value??.
Regards,
Kumar
