winscp.com not returning the prompt
Hallo,
I am doing somthing very simple: I have a batch upload.bat
and the script file
Basically, it works. The Problem is that winscp after execution won't return the prompt to the batch (it does not terminate) and batch processing stops.
I can not figure out what ist wrong.
Thank you in advance for help
winscp.com /script="upload.txt" if %ERRORLEVEL% neq 0 goto error echo Success blat -body "OK" -subject "WinSCP Success" -to recipient@domain.tld exit 0 :error echo Error! blat -body "FEHLER" -subject "WinSCP Fehler" -to recipient@domain.tld exit 1
and the script file
# Automatically abort script on errors option batch abort # Disable overwrite confirmations that conflict with the previous option confirm off # Connect to SFTP server using a password open ftp://user:pass@domain.tld # Upload new files synchronize remote -criteria=time -transfer=binary -filemask=*.jpg D:\UPLOAD /IMAGES # Disconnect close
