Session.MoveFile: Recursive calls not allowed
ksain
Home
I receive approximately 150k files per day from an SFTP site. The files have to be archived in a folder on the SFTP after downloading. Iterating individual files in a loop after getting the RemoteDirectoryInfo is too slow for the volume. When the _session.FileTransferred event is fired, I call the _session.MoveFile to archive the file as they are downloaded. The error below is the stack trace.
_session.GetFiles(remoteFilePath + "/*.*", localFilePath, removeSource, _transferOptions);
at WinSCP.Lock.Enter()
at WinSCP.CallstackAndLock..ctor(Logger logger, Lock alock)
at WinSCP.Logger.CreateCallstackAndLock()
at WinSCP.Session.MoveFile(String sourcePath, String targetPath)
I've a solution that works albeit temporarily whereby I create a second session just to move the files, but if the session is idle for too long even with the ReconnectTime set to TimeSpan.MaxValue, the remote server closes the connection. I've added the Session log and debug log option, but it hasn't been helpful since the app can't tell me the session has been closed until I try to archive a file.
Any help would be appreciated.
Re: Session.MoveFile: Recursive calls not allowed
You can collect paths in Session.FileTransferred event and iterate the collected list after the transfer finishes.
ksain
Home
Thanks for the response. Sorry for the late reply. Collecting the files in the Session.FileTransferred works when the volume is low, but since the task to download wakes up every 10 seconds, it attempts to pick up files which have already been downloaded and processed. Adding a second session that moved files in the FileTransferred event handler works until there is a large cache of files (over 1k) posted and then it slows down enough that we get a backlog of files which we have to process within seconds.
The old and current solution uses the parameko python library which can move (rename) the files in the same session. We are just trying to get away from the python script for a .net solution.
sftp.chdir(rpath)
files = sftp.listdir(rpath)
c = len(files) - DIRECTORY_COUNT
lblStatus['text'] = 'Downloading ' + str(c) + ' files'
i = 0
for rfile in files:
if not blnContinue:
break
if (rfile.endswith('txt')):
i = i + 1
fileCount.set(str(i))
sftp.get(rfile, lpath + rfile)
renFile = renamePath + rfile
sftp.rename(rfile, renFile)
I've also tried a similar path as the parameko solution getting the Session.ListDirectory and iterating files which average 3k in size, but it was too slow for the volume. Unfortunately, I've had to move back to the python script in the interim.
Thanks for you help.
I'll test this scenario.
