PermitRootLogin = No ; switch user to root through WinSCP
ragingspeed
Malta
Recently we had to implement a security policy where all our Linux servers have to have the following enabled ...
As you know, this means that to access Root, we have to login with one of our Admin user names, then switch to root using su - root
Our question is, can we switch to root through WinSCP application after logging in with an Admin user? This is very important to us since we do have numerous instances where we have to use Root through WinSCP
Thanks a lot in advance for assistance and support
ragingspeed
Malta
Re: PermitRootLogin = No ; switch user to root through WinSCP
hi prikryl,
thanks for your feedback.
however we are afraid that this cannot solve our request... we wish to change the user to root through WinSCP in similar way as we do in the terminal emulator that is as follows ...
- login as sysadmin user (provide username and password)
- su - root
- provide root password
Thanks very much in advance for assistance... needless to say that such an option would very much greatly be of value for us
Please read documentation:
https://winscp.net/eng/docs/faq_su
If that does not help, come back.
- su - root
WinSCP cannot prompt for a root password due to constraints imposed by the SFTP/SCP protocols and su implementation. Otherwise the procedure is the same.
