Overriding "Received too large (... B) SFTP packet" error
Linda Kaioh
Hi!
I just updated to 5.7.1 and found I can't connect to KTS servers anymore. I get this message:
https://winscp.net/eng/docs/message_large_packet
I've found setting "Ignores SSH-2 maximum packet size" but it doesn't help me at all.
Looks like this behavior is by design in KTS and this is kind of old software. Can you add option to ignore this error as it was in previous versions?
Re: Overriding "Received too large (... B) SFTP packet" error
Please attach a full log file from both the 5.7.1 and the version that works.
Linda Kaioh
Sorry. Looks like problem is on my side. Old version from autumn 2014 doesn't work too. I can't connect to machines with KTS on same remote network, but for some reason I can connect to local KTS server with same setup. Maybe ISP from remote network block something - I can't figure out.
But PuTTY work well so I thought it was WinSCP issue.
It cannot be caused by ISP blocking the connection.
It's rather a problem on the server.
See your link above for possible reasons.
