Prevent reconnect retry
If one selects a tab that is not connected, WinSCP will automatically try to connect. If it cannot get to the host it will sit there for a while and then will count down till it automatically retries connection.
I would like a way to prevent it automatically retrying after a countdown.
Often I wish to close a bunch of tabs and I would really like to be able to just close them without WinSCP trying to connect to the server as soon as I select the tab. even worse is that it will get into a loop where it keeps retrying meaning that one has to sit and look at it to catch it just when it posts the dialog box.
