UNC path in LNK causing freeze
czbird
When local folder contains a .LNK file pointing to an UNC network path (e.g. \\server\share) and this network path is not connected, then WinSCP freezes, instead of asking for login credentials. Please add an option to disable following any .LNK content completely and treat them as any other files, or at least implement proper network login dialog.
Thanks,
Jan
Re: UNC path in LNK causing freeze
