Get remote path and file into local relative path
gcb-toronto
Hi all,
If my script is running from
C:\temp
I want to get remote file
/root/test.txt
into
C:\temp\root\text.txt
without also getting empty directories from under the remote directory.
How to do this? I have experimented with both get and synchronize and filemasks. I have gotten close, but not exactly what I want.
I was able able to do this under Linux using rsync and I am trying to do the equivalent under Windows.
gb
Re: Get remote path and file into local relative path
Use get /* and exclude everything you do not want to transfer using -filemask=.
gcb-toronto
I am transferring a fixed set of files that are in various locations on the disk of a Linux computer. There are possibly hundreds of files that would need to be excluded. The point is to be able to specifically name the files that I want from the remote device. I don't think that excluding the files I do not want would be practical. Does WinSCP offer any better solutions?
gcb-toronto
prikryl, thanks for pointing me in the right direction.
This is what I came up with:
winscp.exe /console /command "option confirm off" "open sftp://root:password@192.168.0.145" "get /root/MYFOLDER/test.txt" "close" "exit"
xcopy "test.txt" ".\root\MYFOLDER\" /Y
