Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetActiveControl
Goto page
1, 2, Next
domen.jurkovic@...
I clicked cancel while transfering files from my disk to ftp.
WinSCP 5.7.1
[00CF98EE] Vcl::Forms::TCustomForm::SetActiveControl
haziq@...
WinSCP 5.7.1
[010498EE] Vcl::Forms::TCustomForm::SetActiveControl
Re: Cannot focus a disabled or invisible window
manimash@...
WinSCP 5.7.1
[013498EE] Vcl::Forms::TCustomForm::SetActiveControl
ñjnda.lahd@...
WinSCP 5.7.1
[00F898EE] Vcl::Forms::TCustomForm::SetActiveControl
handl@...
WinSCP 5.7.5
(001D9402) Vcl::Forms::TCustomForm::SetActiveControl
abc@...
WinSCP 5.7.5
lesny@...
WinSCP 5.7.6
Trace de la pile :
(001D941E) Vcl::Forms::TCustomForm::SetActiveControl
Re: Cannot focus a disabled or invisible window - Vcl::Forms::TCustomForm::SetActiveControl
jmora@...
WinSCP 5.7.6
Traza de la pila:
wichit.kj@...
WinSCP 5.7.1
[003E98EE] Vcl::Forms::TCustomForm::SetActiveControl
ence@...
WinSCP 5.7.7
(001D9712) Vcl::Forms::TCustomForm::SetActiveControl
ray.hendrey@...
Uploaded several small files via the background queue. When they completed, I clicked the refresh button on the toolbar for the upload site. Then the error dialogue appeared.
WinSCP 5.7.4
(001D9172) Vcl::Forms::TCustomForm::SetActiveControl
tufler_silviu@...
WinSCP 5.7.1
[013998EE] Vcl::Forms::TCustomForm::SetActiveControl
noel.morrison@...
WinSCP 5.7.6
hechoporsiacaso@...
WinSCP 5.7.7
Traza de la pila:
(001D9712)
benjamin.henry@...
WinSCP 5.11.1
(002143CE) Vcl::Forms::TCustomForm::SetActiveControl
ikaneko@...
WinSCP 5.13.1
スタック トレース:
(00216242) Vcl::Forms::TCustomForm::SetActiveControl
emchu@...
WinSCP 5.13.2
スタック トレース:
(0021770E) Vcl::Forms::TCustomForm::SetActiveControl
grant.william@...
WinSCP 5.13.7
Trace de la pile :
(0021857E) Vcl::Forms::TCustomForm::SetActiveControl
wallywaffles@...
I am using WinSCP on my desktop computer, with two monitors, in my home office. WinSCP is connected to a virtual machine guest running on the same host system. In order to use my desktop while sitting with my kids in the living room, I connected from a laptop to the desktop via TeamViewer. While the TeamViewer connection was active, I updated TeamViewer on the laptop (which automatically disconnected and reconnected itself).
My desktop had sat idle for a few hours, with WinSCP running, before I started TeamViewer, and I didn't look at WinSCP until a bit after TeamViewer updated itself, and after doing some web browsing, at which point I brought WinSCP to focus and discovered the error prompt. I *assume* the error occurred while TeamViewer was updating, as that might have done something wonky with enabling/disabling windows.
WinSCP 5.15.9
(00235A46) Vcl::Forms::TCustomForm::SetActiveControl
mhamad@...
WinSCP 5.17.3
(002363AA) Vcl::Forms::TCustomForm::SetActiveControl
boos.taina@...
Pinon jäljitys:
(00236672) Vcl::Forms::TCustomForm::SetActiveControl
I can not save data, I mean changes I have make.
WinSCP 5.17.5
Pinon jäljitys:
rachel.l.nesbit@...
WinSCP 5.17.6
(00236692) Vcl::Forms::TCustomForm::SetActiveControl
rachel.l.nesbit@...
WinSCP 5.17.6
mosheg81@...
Shaking another window that is supposed to cause windows to minimize all other windows while WinSCP is open but disconnected from previous session after PC wakeup.
WinSCP 5.17.5
1342233977@...
WinSCP 5.17.7
(00236772) Vcl::Forms::TCustomForm::SetActiveControl
WinSCP 5.17.5
I have sent you an email to the address you have used to register on this forum.
preetham.pawar@...
WinSCP 5.17.7
ximena.petti@...
WinSCP 5.17.7
ziqian8@...
WinSCP 5.17.2
(00236142) Vcl::Forms::TCustomForm::SetActiveControl
govindansudha@...
WinSCP 5.17.7
dcloward@...
WinSCP 5.17.6
jordi@...
WinSCP 5.17.8
Traza de la pila:
(0023748E) Vcl::Forms::TCustomForm::SetActiveControl
pardiwaladhwani36@...
WinSCP 5.17.8
letraepontorms@...
WinSCP 5.17.7
Rastreamento de pilha:
pechipu@...
WinSCP 5.17.9
スタック トレース:
(0023751E) Vcl::Forms::TCustomForm::SetActiveControl
seanlee907@...
WinSCP 5.17.7
kuppusamy433@...
WinSCP 5.17.9
naduvko@...
WinSCP 5.17.9
hgaugenot@...
WinSCP 5.17.10
Trace de la pile :
(00237542) Vcl::Forms::TCustomForm::SetActiveControl
christian.dupuuy@...
WinSCP 5.17.5
Trace de la pile :
evatryb3@...
WinSCP 5.17.10
arhber@...
WinSCP 5.17.8
Трассировка стека:
.jpg
.jpg
mc.webcreta@...
WinSCP 5.17.10
sgwood63@...
WinSCP 5.17.10
zimmermann@...
I had a disconnect msg dialog and clicked ok.
Then the error happend
WinSCP 5.17.6
scomelli@...
WinSCP 5.17.10
tony.smith@...
I clicked on the server directory and manually changed it to /home/smithto (no trailing "/") by stripping off the sub-directories. I was able to reproduce this. This is easily avoided by using the directory-up arrow button instead.
WinSCP 5.17.10
vicamoal320@...
WinSCP 5.19
Traza de la pila:
(0023C8E2) Vcl::Forms::TCustomForm::SetActiveControl
mariodelimadobrasil@...
WinSCP 5.19.1
(0023CA76) Vcl::Forms::TCustomForm::SetActiveControl
sharkane10@...
WinSCP 5.17.10
Trace de la pile :
julman@...
WinSCP 5.19.1
Trace de la pile :
test1test1.t@...
WinSCP 5.19.1
Трассировка стека:
clarkcountycriminalcops@...
WinSCP 5.19.2
(0023CA82) Vcl::Forms::TCustomForm::SetActiveControl
phmauxion@...
WinSCP 5.19.2
Trace de la pile :
r.spilko@...
WinSCP 5.19.2
nigelt@...
While transferring a large file (15Gb) part way through got an error message and request to report the issue
(0023CB42) Vcl::Forms::TCustomForm::SetActiveControl
WinSCP 5.19.4
scomelli@...
WinSCP 5.19.5
(0023CC0E) Vcl::Forms::TCustomForm::SetActiveControl
diranfolami@...
WinSCP 5.19.5
@diranfolami: Thanks for your report.
vondino@...
WinSCP 5.19.5
(0023CC0E)
peiris.mdhc@...
<Try to describe precise steps that lead to the problem (where do you click, what keys do you I was just trying to open a file. The window stopped responding. Could be due to a metadata file server issue from the server-side.
WinSCP 5.19.6
@peiris.mdhc: Thanks for your report.
alexico8667@...
WinSCP 5.19.6
Трассировка стека:
kdsb.brinkmann@...
WinSCP 5.19.2
Stapelverfolgung:
1@...
WinSCP 5.19.6
Stapelverfolgung:
ignasi.bargallomontoliu.contractor@...
WinSCP 5.21
Traça de pila:
(0023D5DA) Vcl::Forms::TCustomForm::SetActiveControl
moro@...
WinSCP 5.21.3
(0023ECA6) Vcl::Forms::TCustomForm::SetActiveControl
niko.o@...
Session aborts with error code 255 when viewing a folder containing files with umlauts in its name
I have the interface in Explorer mode. When I open a remote directory that contains a file with a german umlaut-u ('ü', Unicode code point 0xFC) in its name, the session abruptly closes with this error message:
Connection has been unexpectedly closed. Server sent command exit status 255.
When I click abort, I get another error message:
Error listing directory '/tmp/media/sda1/WinScpTest/UmlautU'.
Error changing directory to '/tmp/media/sda1/WinScpTest/UmlautU'.
When I click OK there, sometimes (not always), this error message shows up:
Please help us improving WinSCP by reporting the error on WinSCP support forum.
I can click "Reconnect" in these dialogs but it never works. I just get the same error message again. I can also not manually connect to this device, since WinSCP will try to open that same directory again, which causes the same error.
I need to completely close the session tab, open the "Advanced Site Settings" -> Environment -> Directories, and change the "Remote directory" under "Remember last used directory".
In "Advanced Site Settings" -> Environment -> Server environment, "UTF-8 encoding for filenames is currently set to "On", but this also happens when it is set to "Auto" or "Off".
WinSCP 5.19.5
Just to be thorough, I updated to WinSCP 5.21.3 (current version at the moment) and it still happens.
It also happens with other non-ASCII characters.
The remote device is a custom embedded device running a Buildroot Linux. Using FileZilla to connect to it and enumerate the files in that directory works fine, so I don't think it's a server-side issue.
The log file has this error on line 519:
! 2022-09-12 16:15:34.215 FATAL: cannot encode local path name 'ü.txt'
It's very easy to get confused by the encodings here, so I'll spell it out very explicitly: The log-file seems to be properly encoded in UTF-8, since, when decoded with UTF-8, other non-ASCII text comes out readable (e.g. "Mitteleuropäische Zeit").
The log file, at that quoted location, contains the bytes
27 C3 83 C2 BC 2E 74 78 74 27
, which, when decoded with UTF-8 like the rest of the file, comes out to be these Unicode-code-points (in hexadecimal) with the characters corresponding to those code-points above them for easier orientation:
'  à ¼  .  t  x  t  '
27 C3 BC 2E 74 78 74 27
Which looks like the byte-sequence produced by encoding the text 'ü.txt' with the 1252 encoding. But, of course, this is not supposed to be a byte-sequence, since it's already decoded. A sequence of bytes and a sequence of Unicode-code-points is not the same thing. The code-points just happen to all be below 256.
You might already understand this well, but I wanted to explain it thoroughly, just to avoid confusion.
I wrote a program to check possible ways this text could have been mangled and it found these combinations:
Assuming the text 'ü.txt' was encoded with some encoding and decoded with a different one, which combination gives 'ü.txt' as the resulting text?
'ü.txt' -[65001 Unicode (UTF-8) utf-8]-> '27 C3 BC 2E 74 78 74 27' -[1252 Westeuropäisch (Windows) Windows-1252]-> 'ü.txt'
'ü.txt' -[65001 Unicode (UTF-8) utf-8]-> '27 C3 BC 2E 74 78 74 27' -[1254 Türkisch (Windows) windows-1254]-> 'ü.txt'
'ü.txt' -[65001 Unicode (UTF-8) utf-8]-> '27 C3 BC 2E 74 78 74 27' -[28591 Westeuropäisch (ISO) iso-8859-1]-> 'ü.txt'
'ü.txt' -[65001 Unicode (UTF-8) utf-8]-> '27 C3 BC 2E 74 78 74 27' -[28599 Türkisch (ISO) iso-8859-9]-> 'ü.txt'
So it seems there is a really nasty encoding bug somewhere.
My thoughts:
* According to https://winscp.net/eng/docs/faq_utf8#sftp and https://winscp.net/eng/docs/ui_login_environment#utf, WinSCP should automagically not use UTF-8 when the server sends non-UTF-8 file names, but, as explained above, the problem also persists when the "Use UTF-8" option is set to "Off".
* In FileZilla I can select "Force UTF-8" and it still works fine. On the other hand, when I force it to use the 1252 encoding, the file names come out mangled (in this case, "ü.txt" is displayed as the file name, which matches the "ü.txt" -[UTF-8]-> ... -[1252]-> "ü.txt" pattern). This further indicates that the server is properly sending file names encoded with UTF-8.
* The error messages says "cannot encode local path name", as opposed to decode. This could be a typo, but if we assume that it isn't, the problem didn't occur while decoding the byte-sequence sent from the server, but while encoding something. I am not sure what this would be. But the surrounding log messages suggest that it did happen while processing incoming data. Not sure what to make of this.
Description: I am not sure that I want to have SSH keys in a file that I just hand out on the internet, so I redacted those out. Shouldn't matter anyways.
Re: Session aborts with error code 255 when viewing a folder containing files with umlauts in its name
@niko.o: Thanks for your report.
mohan.kumar21@...
WinSCP 5.19.5
@mohan.kumar21: Thanks for your report.
icariantk@...
WinSCP 5.21.3
@icariantk: Thanks for your report.
c.hanauer@...
WinSCP 5.21.1
Stapelverfolgung:
(0023D64A) Vcl::Forms::TCustomForm::SetActiveControl
Freitag
Freitag avatar
I had 5 sessions opened, some on VMs.
From a PuTTY command line on the host OS I killed a guest OS virtual machine that had an open session in WinSCP.
I accidentally clicked on a the "dead" tab instead of the X to close it. WinSCP froze for a while then this error report option popped up.
WinSCP 5.21.8
(0023ECEA) Vcl::Forms::TCustomForm::SetActiveControl
(I already have the update downloaded but not yet installed)
scomelli@...
WinSCP 6.1.1
(003B2B52) Vcl::Forms::TCustomForm::SetActiveControl
roshan.sebastian@...
WinSCP 5.21.7
peter.vandendriessche@...
I was just switching folders. I did however already notice something was off, as a deleting and uploading failed silently multiple times.
WinSCP 5.21.7
y.overrun@...
WinSCP 6.3.1
スタック トレース:
(003C52AE) Vcl::Forms::TCustomForm::SetActiveControl
@y.overrun: Thanks for your report.
dieter.baurecht@...
WinSCP 6.3.1
Stapelverfolgung:
lorensab@...
WinSCP 5.21.8
zimmermann@...
WinSCP 6.1.1
(003B2B52)
i was having connection problems and WinSCP was asking if I want to see the errors it was getting. when I canceled this happened.
Goto page
1, 2, Next
