Setting Remove to True in GetFiles removes the whole direct
andrewkc69
Portland
I am using the latest version of WinSCP, and I am using the .NET assemblies.
In the transferOptions, I set the FileMask. When I get files using the session.GetFiles, and set the Remove parameter to True, it works fine if there is only one file in the directory (and it removes the correct one). However, if there is only the one file in the directory, it removes the file AND the directory. How can I prevent it from removing the directory? The filemask in the code below is being set to ODS*.txt.
 SessionOptions sessionOptions = new SessionOptions();
                    if (job.ConnectionType == "sftp")
                        sessionOptions.Protocol = Protocol.Sftp;
                        sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true;
                    sessionOptions.HostName = job.FTPAddress;
                    sessionOptions.PortNumber = Convert.ToInt32(job.port);
                    sessionOptions.UserName = job.Username;
                    sessionOptions.Password = job.Password;
                        // Connect
                        session.Open(sessionOptions);
                        // Upload files
                        transferOptions.TransferMode = TransferMode.Binary;
                        transferOptions.FileMask = job.PickUpDirectoryMask;
                        TransferOperationResult transferResult = null;
                        if (job.FTPType == "get")
                            if (session.FileExists(job.PickUpDirectory))
                                transferResult = session.GetFiles(job.PickUpDirectory, job.DropOffDirectory, true, transferOptions);
                            else
                                LogFTPStatus(job.JobId, false, "Scheduled", "Fail - File does not exist.", log);
                        else
                                transferResult = session.PutFiles(job.PickUpDirectory, job.DropOffDirectory, true, transferOptions);
                            else
                        if (transferResult != null)
                            if (transferResult.IsSuccess)
                                //The transfer can still look like a success even if no files were transfered. Not sure why
                                if (transferResult.Transfers.Count >= 1)
                                    LogFTPStatus(job.JobId, true, "Scheduled", "Success", log);
                                else if(transferResult.Transfers.Count == 0)
                            else
                                transferResult.Check();
                                LogFTPStatus(job.JobId, false, "Scheduled", "Fail", log);
                                log.WriteEntry("Failures were: " + transferResult.Failures.ToString());
                else
                    log.WriteEntry("No transfers to run");
            catch (Exception e)
                //Write the exception to the event log
                log.WriteEntry("Error in FTP Transfer: " + e);
                //Write the exception to the system log
                LogFTPStatus(job.JobId, false, "Scheduled", e.InnerException.ToString(), log);
andrewkc69
Portland
Re: Setting Remove to True in GetFiles removes the whole direct
Martin,
This is not a duplicate post. At least it's not a duplicate to the one you linked to. This one is about setting the True flag in the GetFiles method and the other one is about using FileMask. Just because I used the same code in both topics, you are calling it a duplicate?? Did you read the issue, or am I missing how the FileMask and GetFiles issues are related?? I used the same code in both posts because they were separate issues. If I am missing something else here that makes them duplicates, please help me understand.
Thanks,
Andy
Sorry, I didn't notice the difference.
